Today I decided to install the tachometer into the dash. I drilled a 2" hole next to the charging meter. I then used a Dremel tool to slightly enlarge it to allow the tachometer to fit. I then reconnected the tachometer temporarily to be able to fine tune the setting to approximately 650+/- 25 RPM. All it took was a slight turn of the adjustment screw to get it set.
When I took apart the dash I noticed the positive line to the light bulb on the charging indicator was not attached. It had broken off at the tiny brass contact inside the lamp holder. I purchased a spare lamp holder and borrowed one of the brass contact and wire. It fit perfectly into the old lamp holder. I wired the 2 gauges with wire leads and connectors attached in order to make it easier to remove the dash at a later date. I used insulated male and female spade connectors.
I ran 2 Teflon coated wires from the engine compartment to the instrument panel to attach to the tachometer. One wire was spliced into the brown wire on the alternator and the 2nd went temporarily to the POS on the battery. (Fused line) I wanted to test the tachometer before I buttoned-down the dashboard. I still have to find a source of 12 volts that is off when the ignition key is off. I also need to Ty-wrap the wire under the hood.
Started up the truck and the tachometer pointed to the 1000+ RPMs cold. Later it dropped to normal idle and read about 650+/- 25 Rpm. I finished screwing together the dashboard. The light also comes on in the tachometer when the headlight lever is pulled out.
Here are some pictures of the work:
![Tach_1.jpg Tach_1.jpg](https://www.steelsoldiers.com/data/attachments/322/322594-72183eacfc3df4155bc6fc06617cf799.jpg)
![Tach_1a.jpg Tach_1a.jpg](https://www.steelsoldiers.com/data/attachments/322/322593-76f4e5de253baad8bbf9a3ec4e8d654c.jpg)
![Tach_1b.jpg Tach_1b.jpg](https://www.steelsoldiers.com/data/attachments/322/322592-5fbeae09c56d16a991abbb3425cbd805.jpg)
![Tach_1c.jpg Tach_1c.jpg](https://www.steelsoldiers.com/data/attachments/322/322590-185cf7ece37a33bbd61a219fe07d7134.jpg)
