rdixiemiller
- 5
- 38
- Olive Branch Mississipi
Bjorn
Look for a pneumatically actuated 3 way valve. Since deuces have an air system, why not? I would look for ones that are single acting, spring return. Set them up to default (via spring) to the diesel side. That way, you would always start on diesel if your air tank was unpressurized. You can find toggle or rotary air actuation valves that mount in the dash for your control source.
28VDC 3 way valves might be hard to find.
You will need to make sure whatever valve you do find has seals that will withstand Bio Diesel.
I can buy 3/8 NPT bronze valves with PTFE packing for about $25 each from McMaster Carr. Mount the valves facing each other and have a centralized lever actuate both at one time. That way you switch both valves at the same time, always.
