- 10,349
- 94
- 48
- Meadows of Dan, Virginia
Okay, tested the dual tank system today. (Ambient about 40F after a night at 18F)
Started the engine on regular diesel. Put the radiator cover on to help warm up the engine.
After 20 minutes the engine temp was about 150F and I switched on the fuel tank heater. 20 minutes later the fuel was at 70F and I switched over to biodiesel. You couldn't tell by the engine sound, but my FDC monitor showed an increase in fuel viscosity and adjusted itself for less fuel. It took 75 seconds before the compensator moved after fuel switch over.
I let it run on bio for 10 minutes and switched back to diesel. This time I let the return go to the main tank until the FDC showed that diesel was at the IP at which time the return was switched to diesel as well.
Let run another 5 minutes on diesel and shut down.
Worked great. Only problem is a leak by one valve (noticed it the other day, still haven't fixed it).
Bjorn
Bjorn
