- 18,181
- 27,325
- 113
- Burgkunstadt, Germany
Get smart first. See if you can not talk to the folks about getting a MEP-831A instead, or money back. If not see if you can adjust the hertz up. And last, but first thing I would do is PM Dewie.
I did PM Dewie, but have not heard back yet. I am supposed to pick it up at 9am this morning. Hopefully I hear from him by thenGet smart first. See if you can not talk to the folks about getting a MEP-831A instead, or money back. If not see if you can adjust the hertz up. And last, but first thing I would do is PM Dewie.
I came up with the concept of the 50 Hz 3 kW for the European market but DRS being DRS they never took off.
The unit is actually built around the 3 kW 400 Hz unit and has a 50 Hz inverter,
The 60Hz inverter will not adjust down to 50Hz and the 50Hz inverter will not adjust up to 60Hz.
Thank you very much Dewie, I plan on calling them @9 this morning to explain how they listed it wrong.I came up with the concept of the 50 Hz 3 kW for the European market but DRS being DRS they never took off.
Bethlehem, I see your also in CTwhere in Ct are you?
I certainly will, so far I have called them and explained to a lady what was going on. She had to transfer me to someone in inside sales. No one answered the phone so I left a message if I don’t hear back by 10 I will try again.Let us know how you make out with the auction house
You are correct they are not very attentive. I soft of made some progress, I was emailed a dispute form to sign and say why I am disputing as well as a "preferred Resolution" I just filled that out and emailed it to them. Hopefully I will hear back soon. My preferred resolution is to either replace it with a true MEP831A in similar condition to the one I bid on or a full refund.Any luck? Waiting on a call back from them too about something else... customer attentiveness is not their strong suit.
Im glad i lost all the bids i placed for these units. Did they turn out to be fakes?Are you 100% positive? There were auctions last Wed/Thur that were called out as not being 831As, but an alternate part number and a lot of similar images. If the heading says that, but the content does not... you might have grounds with Richie Bros. You might not too, if the alternate photos were shown in the listing. Care to share the actual listing you won against? Even if its via private message.
