Help Deuce won't run anymore
jasonjc
290
Gravette Ar.
I can't believe some of you guys took this as a serious post.
I have owned a m35a2 deuce 1/2 not "Duce" since 1999. I know a little about how they operate. I made the post because I personally go crazy seeing all of the post here in regards to why my truck is running badly due running home made/ bio/ cooking oil or whatever. I know the trucks will burn lots of stuff but that is for emergency situations when diesel is not available. For most running this stuff eventually will cause problems.
also I get tired of "how fast can I make it go or how big of tire, what's the biggest motor questions Etc etc etc.
I know it's your truck so do what you want with it.
I suppose I just respect the vehicle for what it is. The longest serving mechanized tactical military vehicle in the history of the world.
The only positives I see is that in the future there should be plenty of parts trucks available after these guys who normally would have bought an old cheap pick-up finally discard their clapped out, blowed up old ex army truck.
I hear you and I was LOL with you the whole time.:driver:
1,183
What I posted was true, well the part where Westy woke up at the Blue Oyster Bar was true.
:whistle:
welldigger
Benton LA
My local crawler shop did literally suggest I dump my drum brakes and switch to a pinion brake. Then they pulled out a brake rotor from a mazda truck and said it would work fine.
I don't think they appreciated my gratuitous laughter.
dangerfieldinc
Beaufort, SC
I have been serching for that stuff from the neighbor to wash mufler with and just found out it was rotor wash from a flight line he worked at.
Dipstick
1,267
Effort PA
How fast will my Deuce go in reverse if I put my transfer case in neutral and take my foot off the brake on a hill? Does it matter if the engine is on or off? I run 11R-20s.
welldigger
Benton LA
Ah I see you discovered the secret to Georgia overdrive. The key to this simple maneuver is NOT being able to see where you are going.
iatractor
19
SE Iowa
This was a pretty funny thread considering most are nothing but serious. For the first several posts, my mind was thinking "the aerial application of birth control did not work". Plus I thought that someone should confiscate the deuce and show him how it is done. Then I realized that the sarcasm was soak and saturated in multi-fuel humor. With that being said, I need to replace my metric crescent wrenches in my deuce with u.s. standards.
machinist75
Murphy, TEXAS
Where's a good place to mount subwoofers in a deuce. Is there a milspec mounting kit maybe from a vender. How about a A-10 rear section as a spoiler?
Big Z
Nebraska
Make sure the clutch is in and close the front windshields. They have fuel-delivery safety switches. They can be tampered with but I recommend keeping the safety features. I had to get towed home 3 different times before I found this out.
