"How to get a HET in life..." - M1070 Acquisition thread
Castle Bravo
Hundredaire Socialite
231
Arizona
Awesome pics, keep them coming!
Sure!
The air filter, out for cleaning. Note the coke can and 5 gallon bucket for size reference. I think almost every other air filter I have could fit easily inside of this one.
The air box where the filter lives.
The power steering reservoir. Note the coke can for reference and the size of the lines coming from it.
The various circuit breakers inside the cab.
A shot rearward from under the front axle. You can see the very large transfer case as well as all 5 gigantic air tanks.
The #2 axle (1st of the rear tridem) You can see how the air brake chambers are above the axles to increase ground clearance.
Here you can see the massive transfer case to #2 axle drive shaft as well as the very large trailing arms.
M1075
Oklahoma City
You will need Soni's 10 Ton crane to do any work on that beast. How many people does it take to lift the air filter?
Castle Bravo
231
Arizona
I need to make a few brackets to get the tool box secured, but this is about where it goes.
M920
30
chama/nm
Man.... I really don't like the looks of the miss matched paint! But then, since I'm having a very generous day....I will take that toolbox off your hands! Just think about all the bracket work and all the painting I would be saving you....lol
Looks great Matt! [thumbzup]
Soni
WRMorrison
14
Ramsey, IL
Just saw this thread; great story! I wish I would have known about this adventure earlier; I would have loved to tag along to recover it!
-WRM
Carlo
21
palazzago italia
sure!
The air filter, out for cleaning. Note the coke can and 5 gallon bucket for size reference. I think almost every other air filter i have could fit easily inside of this one.
the air box where the filter lives.
the power steering reservoir. Note the coke can for reference and the size of the lines coming from it.
the various circuit breakers inside the cab.
a shot rearward from under the front axle. You can see the very large transfer case as well as all 5 gigantic air tanks.
the #2 axle (1st of the rear tridem) you can see how the air brake chambers are above the axles to increase ground clearance.
here you can see the massive transfer case to #2 axle drive shaft as well as the very large trailing arms.
super hd!!!
FASTNOVA
152
Los Angeles,Ca
Took the HET to a car show today, was a big hit. Everybody loves a HET!
You could have atleast put some shine on those tires so it would blend in a little more with the other show cars, but I don't think they sell Amorall in 5 gallon buckets.
Castle Bravo
231
Arizona
I was looking at the HET Lube order today and was thinking about how much of all of the different types of lubricants the truck uses. I made a rough estimation that it probably has something like $2000.00 of fluids in it. (not counting fuel!) Thats about 100 gallons of oils and 23 gallons of coolant, which should weigh north of 850 lbs.
250 gallons of #2 diesel should be about $900.00 on the low end, and weighs about 1750 lbs.
:cookoo:
m715mike
3,921
Montgomery, Texas
So to put this in terms I understand, should I ever have the pleasure of owning an HET, I need to plan on two loans from the bank... One to buy the truck and a second for the first oil change!! :doh::doh:
On a more serious note, I have really enjoyed following your story and checking out the pictures. Thanks for letting me live vicariously through your awesome experiences!!!
