True Knight
- 182
- 43
- San Pedro, CA
From everywhere that I read on this forum and all the 6.5s I looked at the oil feed came from the top of the block in front of the passenger side head. There is not a port there on the 6.2. Some people ran the oil supply from where the oil pressure sender is on the top rear of the block, but they usually said it made the oil pressure show really low. Wherever you get the oil supply from it'll be at high pressure (whatever the oil pump puts out) so you'll need high pressure line. I went with hard steel line. Others have purchased or had stainless braided line made.You'll need a oil supply, the one from the 6.5 won't work on the 6.2. I ran from a plugged port on the block above the oil filter Can you get me some pictures of this? why wont it work? how does it feed from the other side? what did you use to run it? low pressure or high pressure line?
Where I took the oil supply (just above the oil filter):
The fitting on the turbo:
The stock fuel line has a T fitting outside the frame just below the firewall. I used the old line to route the fuel straight up to the filter.
