Hub Studs Sheared Off - Wrecker - Texas
fuzzytoaster
2,932
Fort Worth, Texas
Just got a call from Jeepsinker, he was traveling towards Austin with his m936a2 towing an m923a2. He said his rear left wheel studs on his wrecker sheered off completely and he is on the side of the road. No injuries but the rim is shredded. He has a replacement tire/rim but the studs are beyond repair. Looking for anyone in the area who can assist.
Location: HW-290 between Giddings, Tx and Elgin, Tx (I believe he said 14mins outside Elgin, Tx)
Cell: (337)401-2470
73m819
319
gainesville, ga.
Suggestion, jack up the 939, pull the had hub, pull a good front hub off the 923a2 and install on the 936, LIFT tow the 923, this ALL could be done with hand tools in about an hour or so.
mkcoen
381
Spring Branch, TX
He's supposed to be picking one up for me at Hood Tell him if he makes it that far he can rob what parts he needs from mine to keep him on the road. He may be swapping parts left and right but beats being stranded.
Jeepsinker
385
Dry Creek, Louisiana
I'm apparently close enough to some town that I have 3G now. The 923 I'm towing is not mine and I can't get ahold of he owner, so really don't want to remove his hub, also I'm not sure if I have the tools to remove the hub anyway. What size is the hub nut?
73m819
319
gainesville, ga.
WORSE case use a hammer/chisel, not correct but works in a pinch, always can replace the nuts later, if it means not getting the truck to point B or betting it there less a part that can be fixed a point be, I would rob parts
1,172
Why not just chain the axle up without the tires on that hub?
Tornadogt
Adkins, Texas
Sorry for the double post, Can you jack up the axle and chain the missing wheel side up then just flat tow the 923 slowly until you get somewhere to change the studs..
1,172
How far do you need to go?
Confirm, you have ctis.
Are you flat towing or lift towing?
You can block between the forward axle and the frame to keep the rear axle from touching the ground(since you can't chain it up).
1,172
Fwiw, you can probably chain it up to a frame cross-member too.
NDT
6,140
Camp Wood/LC, TX
Barrman is in Giddings and is a super guy, I will PM you his cell. Agree, need to find a NAPA and replace the studs right there. I will see where a NAPA is or Heavy Truck parts house.
