Hub Studs Sheared Off - Wrecker - Texas
Steelreaper80
96
Indianapolis IN
Current NAPA part numbers for the studs are WA1210 (Right) and WA1211 (Left). Nuts are WA2006 (right) and WA2007 (Left)
Old post but is there a Napa part number the wheel studs for an A2 truck? I just sheared off all 10 of mine and I am stuck on the side of the interstate. I do have the axle chained up and about to limp her back to the shop but I wanted to see if I could get the longer A2 studs from Napa tomorrow. Thanks guys.
simp5782
Feo, Fuerte y Formal
9,436
Mason, TN
No. M939 studs are not a common commercial item. The M39/809 studs are available from napa and will work wa2006 and wa2007 depending on which side you need
Mos68x
36
Seligman,AZ
I just thought I’d add some pics since I just snapped mine today. Still looking for some commercial replacements for the studs and nuts. I tried chain binding the rear axle up, but with approximately 5.8 tons of high grade gold ore material in the back, all it wanted to do was sit on the ground and put too much strain on the front tire. I’d feel better just replacing the studs and nuts on the side of the road instead of trying to limp home and risk destroying a tire in the process. The truck is 40 miles from home so I’m hoping that I can find part numbers I can use quickly.
59F48CAF-FF2A-4539-9901-7F80BDBAE068.jpegF211D7D3-BA8B-4205-96A1-8C26B4109220.jpeg130E420E-CCA5-45EE-A213-95802733FEEE.jpeg3753EF38-B4C8-44F4-8CBB-45542601B6B8.jpeg
Mos68x
36
Seligman,AZ
No worries, I got the PN for the studs from Wes thankfully, I’m just trying to get the PN for the lugnuts now and my Dropbox is fighting with me. Haven’t been able to load the TMs to find the NSN so I can start working out mfr PNs for them
Mos68x
36
Seligman,AZ
You may want to go through and torque check all the rest now too. It was part of every annual and bi-annual service when the trucks were in use.
Agreed, I will once I get this wheel fixed. I suppose it’s possible that they are over torqued, but I’m guessing that wheel got loose somehow.
