galeo7171
- 14
- 18
- Cumming, Ga
I found the leak in my 86 M1009. I traced it up to the injection pump. I took the breather off and noticed fuel leaking from the driver's side of the pump. It looks to be leaking where the throttle cable attaches ( I don't know what the exact part is called). Heres a pic, the leak is coming from somewhere inside the red circle. What do I need to do to fix it. It doesn't leak when the truck is running, only when you shut the truck off.
