- 5,748
- 3,167
- 113
- Metairie/La (N'awlins)
Thanks but I have one already.My cover is available
Whoops, I haven't actually looked at an RF-382 in a while. Power & control is all on the one multi-pin cable, so we should be able to just hook up and test it. I don't have an amplifier, but I can disable my radio's internal coupler and utilize exclusively the RF-382 to see if it at least does something.
The large white cone is an insulator for a different style of antenna connection (wire antennas and the like). Most stuff on-vehicle will use the coax connector nearby that is built for 50 Ohm antennas, which is every vehicle-mounted antenna that I'm aware of. If you don't already have it, you should get that protective cover that 86humv has shown in the pictures below. It really will save that ceramic piece from a lot of potential damage. There's one for about $25 on eBay right now...or perhaps 86humv has an extra one.
No, I have a used one from the first design with my M923 with no issues for many years. This truck got a brand new one but it is a different design made by Narton not advanced and I believe made for the hmmwv's. It has a much deeper face and fit the tabs on the dash perfectly with no modification for the screws. I have read that with the original shorter design the tabs need to be modified for it to fit and hold it.Juan have you had any problems out of your main light switch. I am about to change mine out and was going to follow your lead
Yes Sir, I think we will be ok in New Orleans / Baton Rouge but folks toward Lake Charles and Houston need to "Be Prepared" as my profession dictates......Hopefully Laura won't smash you either.
I found a used set of the unobtainum mud flap close out panels. They keep mud and debris plus water from spraying out. Many new NOS mudflap kits that were surplussed had these panels broken from poor packaging plus take offs like my mud flaps from Southern Metal did not come with them when they were pulled off the bumpers as the panels are on the bottom edge of the tub. Most of the kits on epay do not have them.
They are stupid expensive new from the dealers. It would seem a great opportunity for those with the 3rd printers to crank out some and make a few $.
