Just take the VIN to the local KW dealer or call them. They can usually pull the build sheet and tell you about the truck. Also contact the local agent and ask if it has keys etc. They are usually very willing to help.I was thinking about that too. I might give it one shot at running with new batteries. That 500 mile distance doesn't lend itself to multiple attempts. I wish I knew more about the truck. I'm not even sure if it has a key or if it's 12v or being military possibly 24v.
It's 12 volt, and I'd bet money it is a NTC-400.I was thinking about that too. I might give it one shot at running with new batteries. That 500 mile distance doesn't lend itself to multiple attempts. I wish I knew more about the truck. I'm not even sure if it has a key or if it's 12v or being military possibly 24v.
A good locksmith will probably be cheaper. I'll bet the ignition and door locks take the same key.I just talked to the caretaker of the truck and they haven't been able to locate the keys. I know many military trucks didn't have keys or they were like CUCV's and 1 key fit them all. Do you know what was the case with this k100 model? Kenworth does have a kit to re-key the ignition, doors and tool box but it is spendy.
Thanks,
Greg
BMP uses T.O. 36-1-191, but that won't help.Went to see the truck today. 20 hours driving, 3 hours there.
This truck is going to be alot of work. Rats had built a big nest on the engine, it had 1 battery still in it and I never could get it out, frozen solid, really iced in. Rats had chewed some wiring, but the real problem was I couldn't figure out how to release the cab. Maybe there needs to be air pressure, but I couldn't find the release, whether there is a pump or air. On the right side under the cab there were many air lines disconnected that might be related to operating the cab release.
Somebody had removed the connection from the air cleaner to the air intake on top of the engine so that needs to be removed and checked for contamination at the turbo.
The top of the exhaust stack was removed allowing water, snow and other debris down the exhaust pipe and that looked very rusty. Hopefully no water got up to the turbo and into the engine. The engine oil looked ok. I think I got in over my head on this one. Please advise. I need a manual too.
Thanks
Resurrecting her might not be as easy as you hoped, but it's simply a machine. With determination, "blood, sweat and tears", and of course: funding, you willWent to see the truck today. 20 hours driving, 3 hours there.
Thanks
