ShawnIfert
- 8
- 18
- chatham PA
This is what I have found to be different between an LDS-465-A1 and LDT-465-1D that w
View attachment TM 9-2815-210-34P.pdfI have aLDT-465-1D and I want to convert it to a LDS-465-1A. I have looked over all thepart manuals from the 1960’s all the way to the 1990’s. The LDT-465-1D andLDS-465-1A that were built in the 1990’s are very similar and have the sameCam, Pistons and D turbo. In the manual I have attached there seems to be a fewerrors. The errors are not unusual for a parts manual that has not been inservice that long or the copy I have found was an early version. The FuelInjection Pump listed in the manual is for an LDT and nothing else is listed.The manual shows that both engines use the same Fuel Injectors NSN 2910012142684/ Part# 12354296. I have tried to find where this Fuel Injector is used, but I couldnot find anything. I think if I just use LDS-1A Injectors, Rocker Arms and InjectionPump it will work fine.
I have found that the parts needed for theconversion of an LDT-465-1D to a LDS-465-A1 are the LDS-465-1A parts listedbelow. I had reviewed the parts manuals for hours and this is all I could find differentwith just the engines. But it makes sense. The Rocker Arm allows more air toenter the engine. The Fuel Injector has a more efficient spray pattern. TheFuel Injection pump is timed differently.
1. Rocker Arm Intake NSN# 2815-178-1184Part# 11641735 Qty. 6
2. Fuel Injector NSN# 2910-074-8931 Part#10935284 Qty. 6
3. Fuel Injection Pump NSN# 2910-908-6320Part# 10951115 Qty. 1
If anyonehas anything to add feel free to do so. Any input on this subject is more thanwelcome.
