LED instrument panel lights
Awesomeness
1,523
Orlando, FL
I did have an idea. A simple board diode should work the same, correct?
I don't think it's quite that simple, but still probably doable. I don't believe there is such thing as a "correct voltage LED" (e.g. 12V LED). So you would have to use an LED and resistor to drop the voltage, at a minimum.
Swamp Donkey
The Engineer
126
Gray, GA
Just the first Google search result below. You can get them any voltage you want really, even multi-volt. Still plug and play, just a little more expensive.
https://www.amazon.com/dp/B00VOLU94...t=&hvlocphy=9011194&hvtargid=pla-369103395584
