LMTV Air Conditioner
Bud Cofer
Sebastian Florida
Hello, Anyone know where I an get the green bracket? and also the Pulley for a LMTV 1078 3116.
R-6101-0P Rooftop A/C unit 12 volt
78R1077 Install kit with hoses and EZ clip fittings
75R8382 Compressor 12 volt
75R9970 Compressor mount bracket – please make sure this will work for your engine (NOT!!!)
Bud Cofer
Sebastian Florida
Awesome! This has been a nightmare finding all this parts. I really need three quick. I have to have these trucks done asap. How much are they? Also what are your thoughts on a R-1215 All in one unit. It draws 80amps and and weighs 70lbs. you think the generator, and roof can handle it? it will be a quick fix etc.. Thanks Bud
scottmandu
36
Texas
I'd be concerned that the 100 amp alternator won't be able to keep up with the load and other truck accessories.
ramdough
1,731
Austin, Texas
How is progress on the air conditioners? My understanding is that they are still not cooling well. Any updates?
ramdough
1,731
Austin, Texas
I am actually leaning toward a generator and two roof units. One for the camper and one for the cab. I have to buy one roof unit for the camper anyway and a smaller generator. Maybe just upsize the generator a bit. The end result I think may be cheaper and easier. Just need to know BTU from my earlier question for comparison.
Smike740
17
Columbus, Ohio
Anyone know what the actual BTU/hr rating is for the gen1 and gen2 units?
The Gen 2 is 28,000 btu/hr, not sure about the Gen 1. I have a Gen 2 in my truck, it is workng well however its not been hot enough for a good workout yet. It seems like the issue is the cab needs insulated from others comments.
ramdough
1,731
Austin, Texas
Well that blows my idea of using a ceiling unit. Those are only 15,000 BTU/hr
coachgeo
3,546
North of Cincy OH
Well that blows my idea of using a ceiling unit. Those are only 15,000 BTU/hr...
Maybe not a total blow. We are not in an Iraqi Desert and it is said the AC in a vehicle has a high BTU raiting solely to get temps up fast inside a hot vehicle. Once cool you don't need near as much of that full BTU. So to reduce the need of the start up AC by insulating. Even adding the legal level of window tint could help too. Example insulate the shiat out of your cab and use thick window insulation covers when not in use so cab does not sit there as a solar oven.
I'm thinking of spray foam on interior walls. Not the store bought but the more professional stuff used in houses. Not sure yet but may spray under cab floor as well. If not that mayyyyybe interior floor since I've got to redo fuel pedal anyway or some combination; such as engine side wall and floor where pedals are, and interior walls elsewhere etc.
