LMTV M1078 Tachometer
Keith Knight
2,178
Wauchula, FL
Well I've wasted half a day looking and learning about a Tachometer for my M1078A1 with the CAT 3126B engine. While researching info on installing a cruise control for it, I found the pin out locations on the engine ECM (electronic control module) that it shows a Tachometer output at pins #38 (+) and #39 (-) for the tachometer signal.
I'm finding that a tachometer for this application is impossible?
Any wisdom would be appreciated.
Suprman
707
Stratford/Connecticut
The alternator ac output on the regulator can be used to drive a tach. The datcon universal tachs I have may work off the ecm signal.
coachgeo
3,547
North of Cincy OH
Continue from above
Pin one's wires #3020 at connector...
Pin two's wires ... ....
Got to go. More later, keep getting sidetracked with other projects
My apologies for not yet having finished tracing all the wires in the schematic. With pin one and two somewhat figured out then the signal for the tach must be either pin three or four.
The tach is 12v from what have read in here.
Lmtv772
Banned
651
19
Florida
The Tach is NOT 12V.
There is no advanced degree required, it's right in the TM.
m1078_TM 9-2320-365-20-1.pdf
Whoever needs to know the pin out can look there, or PM me
The correct Datcon tachometer with 3000rpm is available at amazon for ~$100 (Pm for part #)
coachgeo
3,547
North of Cincy OH
LMTV772 is correct in that it is all in the TM
below Post were the first start at breaking that info out. from both the TM and another document (linked to in first of below post). first and second link below is most relevant. 3rd is more detailed and didn't get chance to finish it yet as mentioned above.
http://www.steelsoldiers.com/showth...8-Tachometer&p=1859540&viewfull=1#post1859540
http://www.steelsoldiers.com/showth...8-Tachometer&p=1860095&viewfull=1#post1860095
http://www.steelsoldiers.com/showth...8-Tachometer&p=1860108&viewfull=1#post1860108
As to 12v or 24v..... he knows more than I do on that. Guess if one has doubts than can stick a voltmeter to the pins.
Look forward to someone sharing the part# for everyone
Awesomeness
1,522
Orlando, FL
After reading this whole thread, I'm still not completely clear, is the P901 connector in the dash (by default, without having the winch panel or any extra wiring harnesses that are added in trucks with winch panels)?
TNriverjet
24
Clifton, TN
So LMTV772 (the dude with all the info) is banned? I'd probably buy and install one if we could get a straight answer on the wiring in the dash. Is it there for non-winch equipped rigs?
Suprman
707
There is a small harness that plugs into the dash harness and provides the connectors for the upper box switches and tach. It's in the parts tm. All trucks have a pickup the trans control uses it. You can drive a universal tach off the alternator regulator ac terminal.
Reworked LMTV
Expedition Campers Limited, LLC
1,571
1,217
TN
Can I assume this is the terminal on the regulator on top of the alternator? I see that there is some sort of rectifier in the middle of the truck too.
Thanks!
Suprman
707
Regulator box on alternator/ Front red terminal is 24v regulation. It divides to do 12v regulation. White terminal on back of regulator is ac output. This can be used to drive a tach.
Awesomeness
1,522
Orlando, FL
I haven't had a chance yet, but I want to look through the wiring diagrams and see if there is one for that winch panel harness. I'd like to make a tach harness that performs the same function, but just for the tach without the winch controls. So basically it would plug into whatever connector inside the dash, and provide leads (or a connector, since I have a real LMTV tach) for the tach. Project #62,911 on the list, haha.
Reworked LMTV
1,571
1,217
TN
My regulator is a n3030. I note that some of the other posts with regard to tapping the regulator for a signal, used a different regulator. It only has two posts and one military style connector on the front. Do I still use the the white post?
Awesomeness
1,522
Orlando, FL
I did finally do this by the way. The plug in the truck's wiring harness is located in a spot right in front of the heater, only accessible by taking all the bolts out of the heater and sliding it forward enough to reach down to the plug.
Ronmar
8,358
Port angeles wa
I believe the second terminal on the regulator is a sample of the field current being sent to the field winding. It is used to measure how hard the alternator is working and runs to the STE connector... On a 3116 you can sample a tach signal behind the heater or at the small freq divider box next to the STE connector. Sean Filner just documented how to do this in a utube vid this week...
Awesomeness
1,522
Orlando, FL
There are two models of alternator. The older one, with the N3030 voltage regulator, has the second terminal as a field sense, which isn't going to help drive a tach. The newer alternators have that terminal as an AC line, which will.
