LMTV Shocks Absorbers
Suprman
707
Stratford/Connecticut
LMTV shock bolts measure just shy of 16mm. Rancho RS999036 is 36 inches and compresses to 21.3 inches that should be enough travel I think. Bolt hole on the Ranchos is listed at 15.875mm. The stock ones compress to 20.94 inches by spec and open to a minimum of 33.26 inches.
PowerstrokeNC
Greensboro, NC
Mine have a different size bolt hole top versus bottom as well, are yours like that?
Suprman
707
I only measured one bolt. All of the shocks should be the same though. I have had pretty new shocks they all compress about the same. Made to dampen impacts thats about it.
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
I believe a Gabriel # 83242 will fit. The stock shocks on the front are 20.9449 Compressed and 33.2677 extended. That model Gabriel 20.98 and 33.73. The shock bore is the same. I don't know about sleeve size for the mounting bolt but it looks to be about a 1/2" or 5/8" sleeve. They are reasonably priced around $50 each.
coachgeo
3,551
North of Cincy OH
some one tried the gabriels.... it was a no go cause shock eye ends bolt size were way to far off to use.
Anyone got bolt specs.? same bolts front and rear? Been reported they are different top and bottom.
coachgeo
3,551
North of Cincy OH
...Anyone got bolt specs.? same bolts front and rear? Been reported they are different top and bottom.
while at the truck tonight I got 5/8" shank measurement for bolt at top of shock and 7/8 shank for one at bottom. Though do believe that technically these are metric.
m-35tom
226
eldersburg maryland
16mm and 22mm, but that is an A0 truck. A1R front shocks are 33.5 long and use 20mm bolt top and bottom. Looking to see what A1 truck uses in front.
B-Dog
294
Denver, CO
Here you go:
In case that link dies: Grisby trucks sells FOX shocks (currently on BO) for $290/ea, front and rear.
Replaces: 12414357, 2510-01-372-4839, D-11152, D11152
Order (4) GF-901-100-039 for LMTV (4×4) variants.
Order (2) GF-901-100-039 (front) and (4) GF-901-100-040 (rear) for all MTV (6×6) variants
***Note: GF-901-100-039 is not a direct fit for front upper mounts on A1R Models. Contact us for the fix, if you have an A1R model chassis**
decafe
sewell NJ
Has anyone tried the fox shocks from Grisby ? They look great I just take my truck on beach . But I have got front wheels in the air.
72
60
Seattle Wa
Good question on the Fox Shocks, Anyone???
Also has anyone tried stuffing these ( MSI Defense Solutions 10024848-0001 Direct Action Shock Absorber) onto theLMTV,?? Not even sure what size they are but they look interesting...
Found them on the G.P.:
Third From Texas
6,676
Corpus Christi Texas
Those are just a basic bypass shock. I've not looked up the NSN but I suspect they are for a light vic.
The potential problem with bypass shocks is the location of the bypass related to the mount. Even if they happened to be the right length the "bypass can" could be off 90 degrees and crunch into an axle or frame.
I'm pretty sure that Seth from Adventure Driven is running ICON bypass shocks. But those cost as much as some people pay for their trucks. LOL
