LMTV Upgrades
kenet3621
Blythewood SC
New breather installed... one of the cheapest parts I have put on my truck ($13)....
The old patched cap goes into the spare parts box for one of "just in case" situations.
Feal318000
Ma
curiosity question- is the breather serviceable, or problematic? do they plug up? or is it a part that generally isn't bothered with?
kenet3621
Blythewood SC
From what I have been told there is no maintenance of the breather. It is not a problem unless it is busted like mine was. I think you statement "isn't bothered with" is accurate.
buffalorunner
El Paso, TX
I am ready to extend my breather "down stream" a little. Hoping to have it dump out mid frame instead of right on top of my front axle. Should help keep that area a little cleaner and make it easier to identify any potential leaks.
buffalorunner
El Paso, TX
I managed to get the winch off a scrapped MRAP with the mounting plate, and the plate fits between the frame rails of the LMTV. Going to pull the bumper and use the mounting holes in frame that the tow points use, add a heavy duty angle bracket to each side of the frame that will allow me to use the plate and still have the tow points. Definitely will have to cut the bumper a little (maybe a lot) for clearance. Its most important to me to mount the winch where it is useable and wont interfere with cab tilt or decrease my approach angle. I also want to retain the tow points. I will most certainly post pictures once work begins on this. The only thing that will be very different will be the location of the front gladhands, I will be moving these to on side of truck (if necessary).
DCLund
MN
I decided to go with an electric winch and as many mounting options as possible. I put receivers on the front and rear so far. I'm looking for ideas for swivel mounts on the helo slings.
To the collectors and other purists, I'm sorry I'm cutting up a perfectly good military vehicle.
Another Ahab
4,905
Alexandria, VA
It's your vehicle. If it works for you then you got to figure that it's all good.
What's with the bondo on the front panel?
