gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 748
- 113
- Cincy Ohio
I have filter kits if you want to replace your stock one.
i used a fine threaded bolt, dont remember what size. but common. never had a problem with them leaking. ive done lots . make sure you cut it to the right length, or cut the head off the bolt, or use a pipe plug. this is a low pressure system, 5 lbs or so is all the mechanical pump will do. good luck. thanks. markThanks for all the advice. I tried to plug the small fuel port that went to the pressure sensor with a 3/16" self tapping screw. Made the threads, removed, Teflon taped it, and rethreaded for a really tight fit.
Pressurized the fuel tank with compressor, and the filter leaked. If going the bolt route, I'll have to really tap the hole.
several folks recommended the expansion/freeze bolt. O'reillys did not have anything smaller than 3/4". Did you all use the expansion bolt in the 1.35" diameter hole. It looks like a 1 1/4 to 1 3/8 expansion plug would work if it wasn't so deep. Did you have to cut it to make it fit?
Thank you again for all the help. I can't tell you how much I appreciate it.
