M1010 ambulance box build reference
ballencd
101
Columbus, NC
That does not look bad at all. I would think that foam panels might have a bit more R value but not sure the cost of money and time would be worth it. I guess I will look into how the wires get into that box and see if I can make them work.
Thanks for the pictures!
kapnklug
spencer,ny
So, do you think pulling the walls out and replacing the old insulation is worthwhile? I only want to do this once and I have a blank canvas right now. Seems it would help to get wires where I need them too....?View attachment 925773
Well, Chevymike's insulation is in a lot better shape than mine was, and my M1010 only has 20K miles. I've been replacing the stock bagged fiberglass with 1.5" rockwool & sheathing the inside with R2 DiBond (half the box done now). The plastic vapor barrier on the original insulation had rodent holes, and the wall insulation had settled to only about 3/4 full in each bay. I'm using Rockwool to avoid anything flammable inside the wall (like foam). Also the Dibond is a real help with heat conduction thru the studs -- when the sun was hitting the outside wall, the stock inside aluminum sheathing would get too hot to hold your hand on. The Dibond feels room temp.
ballencd
101
Columbus, NC
Well that is definitely worrisome. I wonder if there is a way to test the insulation value with a infrared monitor and put a heater on the inside of the box. It probably would not work well unless it is cold out which it is not in NC these days. I may reconsider pulling some liner down and see what I find. My M1010 only has about 19K miles on it now and has been in a metal shed for about 25 years but no telling if there were rodents around. I wonder how they would get inside the walls.
kapnklug
spencer,ny
Replacing the interior aluminum with DiBond made such a difference in heat conduction, the work was worth it just for that (still passenger-side wall to go, but the difference is obvious). That aluminum sheet does not come out without a fight tho, the interior corners are doubled and the upper "crown molding" is tough to remove without kinking. Very early into the project, I decided to leave all the corners and just cut the sheathing 1" inside the corner molding, very lightly with a cutoff wheel, then drill out the interior pop-rivets. Then I siliconed over the remaining 1" lip and screwed the DiBond into it, flush with the crown molding at the edges. The DiBond is also the vapor barrier. As I mentioned I also replaced the slumped bags of fiberglass with rockwool, which slips right in but has no vapor barrier of its own. It was alot of work but totally worth it.
kapnklug
spencer,ny
Have you got some pictures of your partial and completed walls and ceiling?
Sorry I didn't take any pics while I was doing it, and now there's not much to see. The driver's side with the DiBond is smooth & white like shower board, while the pass side is still stock. But the DiBond barely gets warm in the sun while the stock side could cook a pancake. For the ceiling, I wanted to significantly increase the R-value without reducing the interior height at all, since I already have to duck my head. So I left the ceiling stock but on the outside put 1" Celotex foam board over the entire roof, aluminum facing up to reflect heat. It's held down by 2x2x8's laid across the truck 16"OC, which are held down at the ends by tie-wires to small C-clamps in the rain gutters. The rain gutters are part of the extrusion that forms the outer corner of the box, they can't come off. There are no fasteners into the roof at all. Then there is a 1/2" treated plywood deck screwed into the 2x2's over the entire roof. So above the stock roof (painted with aluminized trailer roofing) there is R7 foamboard, then 1-1/2" air gap, then plywood deck. Eventually i'd like to replace this with an alumium diamondplate deck with it's own rain gutters, but it's worked well for the last couple years & was super cheap. I could snap some pics of this setup if you like.
ballencd
101
Columbus, NC
I'd love to see some pictures of the roof. Do you walk on it? Solar panels? Plywood seems like it would be heavy....? I like the diamond plate idea......Maybe glue foam to the roof and then glue diamond plate to the foam.I'm planning a RV with mine and think I will pull the walls to verify the insulation is OK before adding anything else. I've got the beds, racks, heater and A/C out so far. It is going very slowly.
kapnklug
spencer,ny
You can totally walk on it. I often use the top of the truck as mobile scaffolding, recently to paint my house with a brush & roller. I have (3) 100W flexible solar panels up there screwed into the plywood with battens, but for scaffolding I throw a blanket over them & then another piece of plywood. It's not super heavy, it's only (2) sheets of 1/2". I wouldn't trust any glue at 65mph. Mechanical connection to the front & side rain gutters is the way to go.
Ya I wish I had started the truck by re-doing the insulation & inner sheathing. I pretty much finished the inside THEN realized this needed to be done.
In the first pic (with me standing on the cab) you can see the orange c-clamps in the rain gutters. A heavy wire goes thru the c-clamp & up to a hole drilled thru the 2x2x8 cross beams. Then plywood screwed into that long-ways, connecting them. Awnings are 8' ARB.
black_wolfnhn
stevens Point Wisconsin
anyone know how wide the area is between the very front of the roof and the first cross member in the roof? getting a 1010 myself that already had the original AC removed and was thinking of mounting a rooftop AC unit as far forward as possible and preferably in the center.
black_wolfnhn
whats the depth from where the front rib meets the roof to the wall up front, most of the rooftop AC units want a minimum of a 14 by 9 opening but the one I'm primarily looking at would have an additional 4.9 inches on the outside roof unit going forward of the hole in the roof and I don't want there to be much if any of the unit overhanging the roof if it can be avoided.
Skinny
498
Portsmouth, NH
I'm so glad this thread lives on! I ended up building a Suburban using the guts of this truck. The box still sits in a field gutted.
Fast forward the Suburban built looks like a loose clone of the truck from the movie Dante's Peak that I loved as a kid. I've owned this Suburban for almost 10 years and it sits as a 1 ton 8.1 rig currently.
Keep fast forwarding a guy in MA found the original movie truck and I'm going on Monday to bring mine down, do a quick photo shoot side by side, then I'm delivering it to the new owner.
I'm surfing the web thinking about a future new project truck. Want something unique and different. HMMWV, M37, M715...I don't know. Googled Isuzu NPR conversion, found someone building one in a solar power forum thread that linked back to this thread about the M1010 box teardown...WHICH IS MY OWN THREAD 🤣🤣🤣
So maybe I need to build an Ambo CUCV🤔 Guaranteed she would get a GEP 6.5, side mount turbo, and an NV4500. Not that I haven't thought it out.
Glad this thread still kicks!
