M108 deuce wrecker engine swap
Welder1
160
Albany Ga
Thanks Chuck the parts cleaned up well no issues. I am available to support others on their projects. My blast pot holds 6,000 lbs of sand and the silo that feeds it holds 30 tons.
Eddie
FloridaAKM
395
Gainesville, Florida
Did you have a hard time welding up the holes in the top due to the rust? The reason I'm asking is that I have some significant rust on a truck I just got that has perforations thru the metal in spots in the hardtop sides.
SETOYOTA
451
georgia
I had the top sand blasted so all of the rust was gone. The holes welded up were from rust. The hardest part was that the top metal is very thin so you slowly have build up the weld without blowing the hole bigger.
SETOYOTA
451
georgia
No pics or actual work, however over the weekend I did find an assortment of “new” hoses for the Austin Western crane. All are unused, pliable No cracking etc. stored in doors with the proper connectors .
cattlerepairman
3,482
NORTH (Canada)
Given the production dates of these cranes, I find it truly amazing that stuff like this still pops up. Are all of these hoses easily changeable once the truck is fully assembled? What I am gett ing at is that, if there is a hose that would be a real PITA to change, that is the one that one might consider having re-made from current new hose, using the old connectors if needed.
SETOYOTA
451
georgia
Once I get to the crane I will inspect and replace what is needed. These hoses I found are 5 years old. A Napa store had the old hose ends in stock and made them for the previous owner. Actually he had 2 complete sets made but when he sold the m62 most went with the truck.
cattlerepairman
3,482
NORTH (Canada)
Congrats! It is such a rewarding feeling when the lump starts up for the first time and runs as if it had never stopped. Good job!
I am still psychologically damaged from my first ever multi rebuild/refresh and in the back of my head expect it to go into some kind of self destruct sequence whenever I start it up.
And, for the record, I am not at all envious of the work space you appear to be enjoying. Not one bit. :)
SETOYOTA
451
georgia
To be honest I still think the whole thing will grenade itself at any moment. I definitely couldn’t have gotten this far without some help from knowledgeable friends . While to some this may be a weekend project for me this has been a huge task . I had never attempted anything similar but I keep plugging along. So far not bad for a guy with no experience and bunch of harbor freight and craftsman tools. :D:D:D:D
My latest issue is I think I maybe blew the regulator on the fire wall. The truck built air to 90psi but then the regulator started leaking. Will need to investigate further .
next on the list is to get the brakes up and start to clean and paint the cab interior .
SETOYOTA
451
georgia
Interior of cab sanded and painted. Installed a new drivers seat. Believe it came out of a m923. Picked it up at a flee market for cheap. If anyone installs one of these seats you will need to drill the seat base holes to match the mounting points in the m44 series cab. The bases are the same size but none of the holes line up.
The seat was wet in the pic
