M108 deuce wrecker engine swap
SETOYOTA
450
georgia
My tool worked great for removing the nuts. I have gotten all the dog bone ends out except for the 2 behind springs. The dog bone itself is gone as the bushing came completely out . I attempted to use a ball joint fork on the back side. (Worked on the other 2 uppers) Hit the casing and the back of the rod repeatedly with a BFH. Even broke my hammer. Got frustrated and decided to attempt removal another day.
Any ideas other than hit it more and harder?
SETOYOTA
450
georgia
I was thinking try a little heat. Going to take a pry par and cut it down and try to knock them out . Or see if I can find an axle shaft
cbrTodd
483
Indianapolis, Indiana
When I did this last year, I hit it with a sledge hammer and a piece of 3/4" round stock and couldn't get it to budge. I melted half of the ball end of one with a TIG torch and it wouldn't let go. By chance a friend stopped by and held the round stock (with a pair of vise grips so his hands weren't in danger) so I could swing the sledge with both hands, and both of them came out with just a couple hits.
So it may just be a matter of being able to hit it harder and more square, that was the break through for me.
SETOYOTA
450
georgia
that will be my next attempt.
SETOYOTA
450
georgia
Ok I went back to the truck today. I put the nut back on each dog bone end part way to give me a little more surface area to work with. Used the same metal rod as before for a drift . 5 hits on each one knocked them loose. Yea me. Thanks for the help
yes I will clean the recessed areas well before putting in the new torque rods.
Redpawn
St.Cloud FL
I see your truck still has it's fold out spot lights on the rear of the cab. Could you measure the pipe from the light to the fold out part for me? I have my ends to fix the lights but the pipes are rusted so bad I don't know how long they need to be.
SETOYOTA
450
georgia
Yes I will measure lights for you. Just now saw this request. Sorry about that .
SETOYOTA
450
georgia
I measured the long poles. The strange thing is one is 55.5 inches and the other is 55.75 inches. Measured each several times .
I mix-remembered your request I will measure the part you actually requested .
SETOYOTA
450
georgia
18 inches
SETOYOTA
450
georgia
Yes this project is still going on. Long story but started doing a few more things to the truck. Working on the top and put the blinker switch and exhaust heat shield on.
