67Beast
- 477
- 63
- Silver Lake Sand Dunes MI.
Well I've had the 4a084 motor running good for over a week now, It just been that I have not had much spare time to get the shelter out and inflated. Plus it has been so hot that you just melt in the sun here which just wasn't helping to modivate me to do it. But finally had some time and good weather today and was able to get a couple of buddies to stop by after work to help lift off the verious piece needed to set it all up. It went up fairly easily ecept for the fact that the PO had packed it the wrong direction so we had to flip it around to get hooked up. But everything went up nicely and the entrance way slid right into place and hooked up. I have found one small leak in a front corner that should be fairly easy to patch. It is a little dirty inside the shelter, and the entrance has a lot of dirt and water marks on the walls, but it looks like it sould all clean up easily. While inside I noticed that the main shelter was made 7/79 and the entrance was 2/78 which means they were deffinatly replaced when it was depot overhauled. I took several pictures and will post them tomorrow when I get to work and can download them on high speed.
