R Racing
- 15
- 38
- St. Leonard, MD
Ok here is the NSN and part # NSN 2920-00-304-3493 and Part Number MS53011-1.
I'll ask, I do need to call to varify VIN. I have read the tow procedures, I just assumed (bad move) that they were still connected.I was looking at the Pics of your truck form the GL link. What you should do is confirm that the drive line is in place! I could'nt telll from the pics. Your trucks front lifting shackles are not in place which means it may have been tow barred. These trucks (as you may know)
need the driveline removed, or axles pulled, or be towed from the rear with the wheels suspended, to be towed for any distance more than a mile or two (the distance is my under standing). It would be a good bet to check on it. Also it looks like the cab clearance lights,
the cat walk deck plate(s), and the trailer brake air supply lines are also missing.
Thanks.Be sure to double check the drive shaft for bends or breaks.
I don't think I would tow that big rig 100 feet on community paved road without brakes. It's going to either push you right through the first stop sign, or melt down your brakes on your truck. And use emergency chains in case something goes wrong.
What size pins are those on the front bumper? Is that a 1" toweye or a 1 1/2"?
BTW,,,, Good luck! Nice buy!
ThanksOk here is the NSN and part # NSN 2920-00-304-3493 and Part Number MS53011-1.
Reading through he -20 there is a lamp body I'll need for the front lights. H6024 is the bulb but I'll need the lamp body and ring to mount the bulb.Found detail pics of some of the lights. The front turn signal i believe is a signal stat 4820 which serves as both the turn signal and gthe front parking light. Same attached to fender with two studs and has a plug on the bottom for the wiring harness in the fender. Rear lights have stop, turn and back up function. Plugs into harness on chassis and a NAPA license plate bracket bolts right in behind it for the license plate which is then lite by a lense in the bottom of the tail light. detail of front shows headlight lantern out. if this is missing any commercial truck with two headlights in the junk yard might may yeild the parts. This is not the same as the 24 v lantern found in a tactical vehicle.
The 400 and 250 use the same starter, if the Duece does to I'm golden as I have one here...I saw a new starter on E bay for upper 3s . Someone on here said the starter for the duece was the same as the 5 ton but it just needed re indexing. If I have time tomorrow I'll see if there is a spacer or not if there is I might be able to fab you 1 up.and find you a bolt size. I have a spare new starter that I can use as a template.
It was only 9 actual work days...LOLJeremy that is REALLY FAST I am headed to Ellsworth next week with a friend to retrieve his Deuce and I believe that EUC took almost 70 days! You have the magic Jeremy I am looking forward to seeing this one to say the least!
KK
