- 1,069
- 1,129
- 113
- Basehor, KS
Good Morning Everybody!
Thank for all the feedback, comments, suggestion, questions and praise we received.
This unit was meant to be a very simple and affordable Auto / Remote Starter, compared to other off the shelf more advanced unit’s but which are also quite more expensive.
As a short introduction about INOVA HIGHTECH, We would kindly ask you to visit this link here:
https://www.logisticsinformationservice.dla.mil/BINCS/details.aspx?CAGE=6ZJM5&DUNS=943202002
We would like to answer a few questions here at this point:
The Auto Starter meets almost all applicable Mil-Std, except that we didn’t perform and EMI or EME test’s up to 40 Ghz, as this unit is not meant to be operated in Combat.
Pre Heat Times:
The Pre Heat Time is cumulative. As where the Switch turns the Pre Heat On and Off with each move off the position off the switch. Each change in switching position causes the Glow Plug to cool off by several 100's Degrees.
On our board, the Pre Heat is on until the Generator switches to RUN MODE
I guarantee, that this board, as long as the Glow Plugs are in fully working condition will start the unit successfully the first time even in the coldest winter days.
IMPORTANT: FOLLOW THE MILITARY INSTRUCTIONS FOR OPERATING IN COLD CLIMATE OR SPECIAL SITUATION AND CHANGE YOUR OIL AND DIESEL ACCORDING TO THE MANUAL.
NFPA-110 industry standard:
Applies to Non Military Grade Generators, which have a different internal electrical structure all together.
There are only a few possible startup failures for an MEP:
1. Low and No Oil Pressure
2. Defective Glow Plugs
3. Problem with the Fuel Supply
4. Malfunctioning Governor
The Circuit Board monitors the Oil Pressure and Over Heat Circuit. The Input starts monitoring the Oil Pressure circuit as soon as the Board goes from Startup to Run. If the Oil Pressure Switch is not engaged at this point, then the board assumes that there is a problem with the Generator and prevents any further starts to protect your valuable asset for further damage.
Simply pull the DC Breaker for about 5 seconds and the Board will reset it self and you can go through the Start Procedure again.
Manual Start and Operation with Switch S1 are not affected when the board is in LOW OIL Mode. Only the Auto / Remote Start Option is disabled in this event.
Follow the Original Military Manual for selecting the appropriate Engine Oil, especially in Cold Weather. A lighter weight Oil will built up Oil Pressure faster and protect your engine much better.
Installation / Operating Manual:
Please sent us an email: sales@inovahightech.com
with subject: MEP Autostarter Manual
We will start sending them out tomorrow [Saturday 12.07.2013] via reply e-mail
Repairs:
We can fix and Repair any of the Boards from any of the MEP Series Generators. We have most of the Original NSN Parts in stock or suitable replacements.
You need to mail us your defective circuit board.
Thank you! Peter E. Albrecht
Pre Heat Times:
Repairs:
