Mep 006a
mwhiddon
36
Louisiana
That makes it a utility set push the button in the side of the knob and push it into make gross adjustments down or push the button and pull to make gross adjustments up turning the knob counter clockwise and clockwise make fine adjustments with no load set it to about 61-62 Hertz using a digital multimeter on the output don't rely on the set gauge they're not exactly the most precise things and let it be as the load increases the motor will droop so keep an eye on it you may have to play with it a little bit anywhere between 58 to 62 is a safe range to run 60 being ideal
I put the digital multimeter on it and it’s putting 60 -61 hz same as the gauge. By the way what do I need to do if the engine droops? Would I turn the voltage up a tad or let it be?
Scoobyshep
1,969
Florida
It would be frequently that droops, if needed adjust it as needed. Beware though when the load lightens it will go the other way
mwhiddon
36
Louisiana
10/4 I may just try to see if I can get it in a safe range and let it be if possible. Wonder how many kw I sacrificed since it’s been converted.
Scoobyshep
1,969
Florida
That subject is one that tends to start a huge flame war. Let's just say that you have enough overhead on that set you won't have to worry about maxing her out.
mwhiddon
36
Louisiana
You're very welcome. Glad you were able to get it all setup. Keep in touch
Just to touch back with y’all generator was wired to the house finally and worked well electrician works on them from time to time and said it’s smooth running and putting out and doing it’s job with everything in the house on it only used 40% power may end up tieing my uncles house to it as well.
