seek
- 0
- 6
- Mocksville nc
Hello
My first mep and every indication is, it is brand new. It just looks perfectly new.
So when I have been read posts I have kept in mind they have been talking used at some point in the advice given and thinking that could be different if its never been used.. The manual has the oil change schedule at 125 hrs. When I get this setup how long should I run it before make the first oil change? On fuel should I add anything in the fuel for the first run? I am sure you could do many posts on fuel but I am mainly talking first run here. How long should I run it the very first time or does that even matter. They probably just fire them up and use them but its mine and if I can make a difference I would like to. Regular 15-40w first use then 5-30 full synthetic, thereafter?? Change oil filter at same first change?
I ordered starting batteries for it and they are scheduled for next week. I have yet to install a grounding rod. I felt it would have a rod but it did not. Last question, can you have a external fuel line made up or do you have to use a OEM one? Fittings, size?
If you can add something please do.
Thank you
Post #5 General recap
Post #6 has been updated with information on using the load terminals successfully with 120v ph1 straight up on the MEP-016B (read post #15)
Post #9 was undated with information on consumables, fluids are in post #5
Post #11 has technical info on the fuel cap and vent and battery install alternatives
Post #15 shows final outcome of Delk's service on using the load terminals.
Post #18 new onan Q106d engine break-in
Post#19 30 amps to use with 120v appliances
Post#20 onan part note on aftermarket transfer pump
Thank you
