deherenman
- 0
- 1
- Texas
Legally Blind poster here.
Bought MEP-803A back in Jul of 2023 Running off GP. Did fluid change oil, coolant, All filters/canisters. Replaced fuel return line from CallMeColt kit. New fuses thanks to help from Kurt. New batteries with battery maintainers.
Unit would start almost instantly. Ran the unit about 10-15 hours all told. Unit has 6400 plus hours.
Main issue I am having. Since February of 2024 I can not get the unit to start. I could get it to start with either / gasoline on a rag. I know not good for unit. Stopped using either now have WD40 Acts like it isn't getting fuel.
On oil filter side of engine Fuel solenoid is working moves back and forth with key is turned.
Getting stream of fuel out of fuel metal line where the low pressure line connects. Getting fuel when cracking metal lines just below main metal fuel line.
When cracking the lines at the point of each injector I don't seem to be getting much if any fuel on top of engine.
Now if i remove air filter rubber hose and spray diesel fuel direct in to air intake after air filter unit will run but only until spray fuel is burned up. Seems like " fuel rack " not sure how to access fuel rack? See shared video.. I have been through TM 9-2815-253-24. Fuel system / injectors.
Please point in right direction. Keeping in mind I have vary bad eye sight.
1st Starting July 27 2023
Fuel stream Jun 24 2024 https://youtube.com/shorts/GrJ3Z_p8Z74?si=nTipfcEMYw8vQqQY
Will not stay runing Jun 24 2024 https://youtube.com/shorts/JGc_Bwa21mc?si=rfciDNUqUkNOYjpd
