Mep 831A load issues
2Pbfeet
1,475
Mt. Hamilton, CA
Also both injectors looked the same when they came out. Pretty coated in carbon. It's that pretty normal?
Not in my experience. It seems as if your engine is being overfueled.
If it were me, I would go back to try fueling the high pressure pump directly again and see if that improves your load and smoke. If it doesn't, I am starting to wonder if pulling the engine to check the camshaft timing and the rings might be in order. Sorry.
All the best, 2PbFeet
grywitt
203
Nm
It will be a good learning experience. The more I dig into this thing and study the more I learn. It does seem like 1 degree of adjustment isn't leaving much room. This is the one shim under the fuel pump. Soon I'll get set up and start digging in. I'll post pics and I'm sure have some questions along the way.
vrzff
109
33
Mont Vernon, NH
Question. What happens if you run it with no air filter?
Next question. Do you have an air compressor? Next time you load test and it starts to stumble, start blasting some air into the filter housing (with filter in). Don't go nuts, just a steady low-force blow. Does it catch back up and stop stumbling?
grywitt
203
Nm
No air filter is the same. I'll try the air trick but I've pretty thoroughly checked the restricted air possibility but ill try anything since i obviously don't have the answer.
grywitt
203
Nm
Quick question? Does any body have a recommendation or warning about gasket kits for these? I see many options on ebay. I just don't want to make the mistake of using junk or are they all the same? I suppose I should change any gasket i open right? I thought I should put new sleeves on the valves too while I'm in there. I guess I will need a spring compressor? I've never taken valves out before. Any advise is welcome and appreciated.
vrzff
109
33
Mont Vernon, NH
I generally only change head gaskets, and reuse others that are not torn. I've had very good luck with the Ebay ones.
LuckeyD
341
Vilseck, Germany
The 831 runs at 2 speeds. No load(or lite loads) and heavy load speeds. Attached is how you adjust the Governor.
The magnet setting to hold the governor lever in the stop position is Factory set. If you mess with it all you have to do is adjust it back unscrewing it till it holds the plate again. At low or full loads the plate is about 5/16 to 7/16 of an inch away from the shut down held by the magnet position. The plum wire was used to set the high end of the engine for full load highest setting 3800 RPM. Just use a DMM to measure ACV at Pins A to C of the Governor control in the control box. 178VAC at no loan and 194 at full load, and it shuts off when you shut the gen down, and you are in business.
grywitt
203
Nm
Copy that. Thank you. I feel like I have done this. The wire and lead were in tact when I got the unit so I'm thinking those are at least where the factory put them. The lead has since fallen off but the wire is still in the hole. I did adjust the full load voltage with the actuator held in the the manual start position. I'm having trouble with the actuator arm slipping on its pin but I will get that straightened out if I have to drill a hole and pin it.
grywitt
203
Nm
I made this video of checking the injection timing. Can anyone tell me if it looks right or I'm doing something wrong. This video is with no shims under the injection pump because I haven't put it back in since I decided to see what would happen if I took it out. I watched a u tube video of a guy that said if you are at 3 to 4000 feet try taking out a shim. The one shim it had/ has is the smallest one. You start seeing some fuel at about 4 or right in that area. But the larger amount of fuel is between 3 and 2 marks.
grywitt
203
Nm
I've made a few videos of different tries angles ect. I put the one shim back in and if anything i think it shows more that I need more. Probably it was the fact that I hooked up batteries and had the fuel pump running though.
I'm wondering if someone pulled the pump and only reinstalled it with one shim. I feel like I might need 5 degrees of shims ish. Please if you are taking time to look maybe check my other videos also. That way I don't need to post links to them all.
Thanks again
grywitt
203
Nm
I'm going to set it up with the fuel injector hooked up but not in the cylinder then try to see exactly when it pops. Seems like the only way to know for sure. I'm not fully understanding the TM on how I check the timing. I thought that's what I was doing.
