CommieGIR
- 38
- 13
- Cheyenne, WY
Yep, was damp. Back to semi-working, now can't get power out of the outlet even with indicated power and battle short on.
Yes, it's at the very back of the -13&P TMYup, let it run for about an hour.
Kloppk: Is there a good wiring diagram for the relays/power/switches? I thought there was one in the TM but cannot seem to find it.
I’m just reading some past threads. Did you get the gremlins worked out on this 831A?I will give it a shot, thanks Kenny0
Still selling those kits? please PMNo schematics or trouble shooting info for the inverter. It's a pluck and chuck item.
High humidity can cause issues with them. Have you had high humidity lately while you've been working with it?
The rest of the generator is pretty solid.
I have a supposidly good used inverter on it's way to me. If it tests good that may be an option.
Also the PMA and Inverter can be yanked out and replaced with a conventional gen head. I've done that to several 831's. I have produced gen head swap kits with a new GC, wiring harnesses, hardware and instructions on how to do it.
