Mod of the day - bed crane
Kohburn
SOMD
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I need to do something like that for my 500lb tire/rim combo. Good luck loading a flat tire in the bed on my own.
Kohburn
SOMD
I haven't tested the winches single line capacity yet. but so far it handles what I need it to. I've got a pulley block for it to make it easier on the winch.
m16ty
210
Dickson,TN
Gimpy, I've got one that I may be willing to do some trading on if you're ever down my way :wink:. It was mounted in the back of my M715 when I got it but it wasn't fastened very well to the bed. I took it out and it's just been sitting in the barn ever since.
Kohburn
SOMD
Kohburn, one of these days can you please take a couple of pics of the base? I'm wondering how its mounted.
3" angle iron 12" long
two pieces of that overlapped and welded. the pipe is bolted to one of them using 4" long 1/2" bolts
there is one 1/2" bolt holding the top of the angle iron to the side of the bed, and two 1/2" bolts through the bottom angle iron as close to the edge as possible so that they are bolted through the main support under the bed.
unfortunately the crane is in the way of the troop seats folding down. but i made it so that all i have to do is unbolt the two 4" long bolts and the pipe upright comes off. so it's only a 2 minute job to remove the crane.
I'll get some pics later.
M215
Spotsylvania, Virginia
I Have been considering the same set up on the drop side 5 ton. May opt to install the hoist at the front of the bed next to the spare tire. On the 5 ton DS the foward two feet of the bed sides are fixed. So no problem with troop seat clearance, but the cargo cover would have to be removed to use the hoist.
Thanks for the motivational pics
319
Lieutenant
49
Michigan
You could section your left troop seat and add an additional support such as in the attached photo
MO MV man
Imperial, MO
I've been thinking about this mod for months.
I love the way yours came out, Kohburn!
But the crane I've been thinking about is this one.......since it already has the vertical/upright portion and a winch (albeit manual):
1/2 Ton Capacity Pickup Truck Crane with Cable Winch
I think this thread might make me finally get my rear end in gear and install one.....it would make getting stuff in that bed worlds easier on my bobber!
Kohburn
SOMD
I would have used that one if i didn't already have the short one to work with.
would be easy enough to mount and motorized winch for lifting. just have to add a little reinforcement under the bed and bolt it on.
92RT-TT
Hudson, WI
Thats a good idea to add a little crane. I'd section the troop seats too so you dont have to remove the crane all the time
maddawg308
729
Front Royal, VA
That's an awesome mod. I'll have to make that a reality sometime next year....
Sure beats that hand-crank one that clinto had a few years back.
SSWaters
Kannapolis, NC
I built one for mine awhile back, seeing yours I should have incorporated a folding feature like that. I buy and sell Rockwell axles and it'll pick up a 5 ton frt but the 2.5 tons are easier on it. Just have to have the truck level when using cranes like yours and mine to be able to swing it in/out. It's a handcrank with brake, no wires and switches to worry about for simple stuff.
srodocker
68
Lacey, Washington
cant wait to buy my sooner or later. going with the manual one just for simplicity. would be sweet to have something to ride the quad onto and have it be able to roll off into the bed
