Well it made it home this morning. I decided to have it transported instead of driving the 650 miles. Cost me about $400 more but no hassles or worries. I did a quick check and it seams to be leaking coolant from the heater core. That will be top on the list to fix. I need to see if I can just shut off coolant going to the system so I can pull it and take it to a radiator shop for checkout/fix. The motor looks like it has new oil in it ! I will also check the axles, transmission and transfer case for proper fluid levels. Starts very easily.
Couldn't see if there is an alcohol evaporator for the air system. I would really like to add one if not.
The hand brake leaks air when in the off position ? I'm not sure how its suppose to work. The leak is in the left middle wheel/brake assembly somewhere. I do have the TM's but advice is always welcome !
The lights are a little intermittent and playing with the 3 lever light switch causes them to me intermittent so I'll order a new one. It doesn't feel crisp when I switch it.
The passenger floor area has some rust holes so I'll be doing some cutting and welding to patch there as well.
This is definitly different than my Deuce ! A whole new beast for sure.
I used Truckdeals.com, Walker Price was the guy and was excellent in setting up the transportation $2/mile
I will get some more pics up tomorrow, I've already done some cosemtic work on it as well.
Long productive day and very fun
