- 8,226
- 20,774
- 113
- Charlotte NC
.What a day. I replaced the trailer and park brake valves on the dash today. Uh... There is like no room in there! That had to be one of the most frustrating things I've done so far. Now that those two huge leaks are gone, I killed the engine, released the brakes and heard more hissing. Got out the soapy water and found this. IN 3 different pots! Ugh... Isn't the diaphragm replaceable? It's the larger one leaking. I can still hold 120psi pressure. I also put a kit in the air dryer. It's the original finned unit and works fine.
There is a pretty good post here that explains what you need to know - along with warnings about what will happen if you release that bolt where the big bubble is in your picture (without the caging bolt in place). This is a 2015 vintage thread, but there is a LOT of good information in it as well as links to the proper manuals on how to do what you want to do - safely.
Can someone explain these brake canister bolts to me?
Brake canisters, one has bolt, the other side doesnt. What is their purpose and do they need to be there?
www.steelsoldiers.com
