Monkeyboyarmy
- 192
- 63
- Kingsville,Oh.
That air looks perfectly normal to me.The steering is pulling air off of the secondary side and is being re-filled by the primary side.There is a sudden drop in pressure because you are using a large volume of air to re-fill the air assist cylinder that if I recall correctly is 5" in diameter.As you continue to turn the wheel,it is just adding a little more air to fill the area in the cylinder that the piston is creating as it moves.The real test on the steering is like milbri09 explained.With the truck off and pressure built up,turn the wheel all of the way one way.If you get just the initial drop in pressure and steady after that,then the steering is leak free.If you turn the wheel all the way and the air pressure slowly drops,then you have a leak.(Most of them leak.The cylinder bores corrode and pit up).Probably still OK.Just wont have as much power assist.
