- 4,640
- 32
- 38
- Cambridge, Ohio
He has a blind left ear????????????????
You got it!kenny, I'd like the timing light please sir!
I would like a ladder for my m101a2 I just had knee surgery in both knees and could use an easy access 'ramp' how much $ ?Got some more boarding ladders, some are spoken for. I will have new mil spec cold start $15ea and will be bringing an NOS in crate AO42-3 mule gen set motor $350View attachment 455094View attachment 455095View attachment 455091View attachment 455088View attachment 455129
ill take the CJ5 grill screenI have a few more items to sell, and I'm only bringing them if they are sold ahead of time...
Takeout M35A2 radiator. I removed this from one of my trucks earlier this year. It did not leak, held pressure, and maintained temperature fine. The steel vertical support on the drivers edge of the core is rusty, and the expansion of the rust has pushed the mount loose where it was soldered to the upper tank. The lower tank support is also coming loose. Replace the rusty part and resolder the mounts to the tanks and you'll have a good radiator. $60
Pioneer tool rack $25
CJ5 Grill Screen $15
Military cargo tie towns for use with 1/4" chain. $15 each or $50 for four
Two nice M16A2 replicas with real stocks, handguards, pistol grips, and front sight housings on steel barrels. Assembled on a solid aluminum receiver with no moving parts. $315 each.
Do I have anything you want to trade for that? You can have clintogf-she's really nifty!I can also bring a LDS that ran great when pulled. No turbo. Has 5ton bellhousing on it still. Appears to have a coolant leak from rear headgasket, not 100% sure. With 5ton power steering pump- $1300 Without- $1000 I will only load if I have a commitment ahead of time for it.
WOW! I hope you edit that before she sees it! Nifty huh? Would not want to be in your shoes!Do I have anything you want to trade for that? You can have clintogf-she's really nifty!
