Operation "URGENT RESTORATION"
m38inmaine
102
Maine USA
Finished sanding the two front fenders, inner fenders and engine cover. Hit all the bare spots with zinc chromate primer. Got the first coat of forest green on the engine cover. Another long day of sanding and painting tomorrow as it may rain Saturday.
m38inmaine
102
Maine USA
Thanks guys, I spent a lot of time sanding those fins, what a pain. A few are bent but there is just so much you can do, they are pretty fragile.
m38inmaine
102
Maine USA
More sanding and painting today, bottom and top of front fenders 1st coat of green and primed the carrier front rack. That rack was time consuming for sure, a lot of surface area.
Jericho
72
Landaff NH
You will be fine. In the same boat, M109 paint touch up not any where near done and refresh on Goat paint is stalled for now at one fender, You have done well, will be nice to see it as it comes from the grave reguardless
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Mark,
Do you have more pictures of your tailgate?
Both of mine have a sheet of plywood screwed to the inside. Yours looks a lot different. Maybe an original production. Do you have an early VIN / Serial# on that goat?
Sent from my Galaxy Nexus using Tapatalk
m38inmaine
102
Maine USA
Tony, it was a NOS tailgate however the box got wet and it rusted pretty well in the recessed area. It did originally have a sheet of plywood and a sheet of steel over that sandwiched to the back of the gate. It also had a piece of angle iron across the top of the outside of the gate. I believe these were attempts to make it stronger as the originals did not have these features. It may be hard to see but mine has a lot of pitting, I plan to buy a new one but don't have the funds to spend on it right now. My carrier came from a different tractor so I don't know when it was made, the tractor is a M792 REG 03C93770 MFG 1971.
Pictures are of an original tailgate, no upgrades and it's lighter weight.
