Operation "URGENT RESTORATION"
quarkz
Supreme Galactic Cleric
129
Kennewick, WA
Can you use a jack, and a bar/rod and the weight of the engine to ease it up?
Maybe a bit of tension, then tap and heat from the top?
Good luck.
m38inmaine
102
Maine USA
Tried the jack, all it did was lift the engine off the stand. Plan B is to take the engine back off this weekend, lay it on it's side and have more room to work with a large hammer and bar. On a more positive note the oil drain valve arrived today, this will make oil changes much easier, $20 shipped.
wsucougarx
65
Washington State
I ordered the same one. Did you get yours out of Canada? I've got the filter and 9 qts of Rotella T1 just waiting. Finding a single wt diesel motor oil was the biggest challenge. Seems no one carries single wt with the needed CF2 rating.
mkcoen
382
Spring Branch, TX
I was able to get it at Walmart. Of course the filters were a different story.
m38inmaine
102
Maine USA
Plan B was a success, tipped the engine on it's side and with a long bar tapped the sleeve assy. right out. Too bad they were stuck, the sleeve still had very heavy cross hatching, this engine was in very good condition. Oh, and it is for sure is wet sleeve, end of debate.
m38inmaine
102
Maine USA
No, it looks like the engine was almost new inside, I am even going to try and salvage at least one sleeve, all the rods and pistons. I am going to split the bad sleeve and try and recover what I can, the other two actually passed oil and the third was not stuck at all. I will know more tonight.
Update: Was able to save one piston/sleeve assy. from #3, #1 and #2 were stuck and I had to drive them out of the sleeve and the sleeve was pitted. Did save the connecting rods and pins though.
m38inmaine
102
Maine USA
HI Tom, teardown is complete, standing by for some parts for the rebuild. Also need to source one of those engine gasket kits you have and 2 more sets of rod bearings. The crank is smooth as silk, interior of the block is clean, no sludge. Only thing needing a cleaning is the water jacket area that has some goopy residue from sitting. While taking a break from the engine I have been blasting and painting those parts you sent along. I may need some advice from you friend when it comes time to adjust the injector "rack", look forward to his initial report.
m38inmaine
102
Maine USA
An organ donor container?, well almost. Big thanks to Mark in Texas(and his faithful assistant keith-j) for sending along the piston/sleeve set from his old engine. This will get my engine back running again, so one engine saving another. This group is really fantastic, the parts exchange and information shared has been the best I have ever experienced. I just wish we were not so far apart, a goat rally sure would be fun.
