Operation "URGENT RESTORATION"
m38inmaine
103
Maine USA
Received a parts shipment from AR today, arrived quickly. The air duct is not a separate part from the hull so getting this was special indeed. I was very surprised to see the top bow support rods, these are hard to find. As with the air duct my transmission shift lever was bent from the de mill operation, this will fix that nicely. Two new end curtains a surge tank, defrost duct and radio connector fill out the shipment. Big thank you to Tom for the relay from RR for some of these goodies and the effort to remove them from the parts hull, no small task.
combat32
107
Booneville AR.
Glad everything made it ok, that sure was fast.
And I got the 34 manual in the mail today, much appreciated, I have it on digits but it's just better to have a manual in your hand!
m38inmaine
103
Maine USA
Exciting news, I bet the "other" Mark knows what it is. Sorry I missed your call, was outside installing a new fuel pump in the M1010, about as much fun as working on the Goat.
mkcoen
382
Spring Branch, TX
Yep. Shouldn't that have "fragile" stamped all over it? Hopefully the UPS guy doesn't drop it on his foot.
m38inmaine
103
Maine USA
Have the air box fitted that Tom sent so I decided while waiting for the M1010 battery to charge I would spray some forest green on the parts. The first piece is what is normally welded into the hull. I epoxied 3 additional mounting tabs to the floor and used speed nuts as used in the rest of the box to mount it to the floor and front hull. Now I can remove it to gain more access to work under than dash if needed.
m38inmaine
103
Maine USA
Tom came through again, cylinder head arrived from AR today. It may not look very big but it sure is heavy! So far it is cleaning up nicely, it survived the ride just fine as far as I can tell. Big thank you to Tom for the ride and Mark for making it available.
mkcoen
382
Spring Branch, TX
Glad I could help. Hopefully there wasn't any damage from the overheat issue. As heavy as it is and the limited time it was overheating I can't imagine that there would be but you never know.
combat32
107
Booneville AR.
That black foam material I put underneath makes a perfect cover to go in the air scoop when cut to fit. I find it helps to keep rainwater from gettin in your floorbards.
Hope no one at FedEx slipped a disc luggin that thing around!
m38inmaine
103
Maine USA
Today I relocated the wiring terminal board from the back where it is unreachable to the side where it can be reached. I took a spare cucv terminal board I had and mounted it to the original plate. The cucv one uses a nice cover with thumb screws, the M561 cover requires you to use tools and loosen the mounting bolts. I also noticed that the insulation had pulled back on the main wire on the engine harness connection on the chassis side. This made me quite nervous having that 24v wire exposed so close to the metal shell of the connector. I took a punch and knocked out both sockets, I then used 3/4" adhesive lined shrink tube and then with a little bit of silicone grease pushed them back in. TIP: use a step drill when enlarging ring terminals, it doesn't catch and tear the ring like a standard drill. I had to drill out the terminals to 5/16 to fit the cucv tb.
m38inmaine
103
Maine USA
Exactly the same as mine, must be a common problem, I see a warning about it in the PS magazine. Thanks for looking, hang on to it in case I can't find a complete one, thanks.
