Our MTVR camper:
MTVR
749
Waco Texas
After two weeks off due to wildfire smoke and then rain, we hoisted our drawbridge for the first time today- the winches worked perfectly.
We still need to mount the hinge, before we can lift the drawbridge completely up into it's recess, but it's nice to finally have our box enclosed.
We're planning to put our first coat of epoxy on the outside walls tomorrow.
MTVR
749
Waco Texas
Four coats of marine-grade epoxy on the left, right, and front outer walls, as well as inside the nesting area for the drawbridge.
We already had six coats on the roof and three on the bottom of the floor...
MTVR
749
Waco Texas
After a massive amount of surface prep, I let my wife roll on our first real paint yesterday, and we are happy with how it looks.20201004_181229.jpg
MTVR
749
Waco Texas
We've had so many interruptions- most recently, I had to fly to Texas for a few days to buy a ranch. It will serve as a central base of operations for our exploration of the U.S., and it has a 2,300 square foot shop with 14' tall doors, to store our MTVR in.
Today, in spite of the increasingly sketchy weather, we were back at it. We sank the last 12 of 28 box-to-bed mounting bolts. We are both super-stoked about that.
Tomorrow, we plan to start cutting and installing the 3.5" thick polyiso foam insulation boards in the walls and ceiling, and then foam the gaps, to make them airtight...
MTVR
749
Waco Texas
I'm not very happy that the timing of this move will likely require tire chains, but I did score a set of four military surplus Oshkosh 16.00R20 tire chains for $400 with free delivery. I'll need to test fit them before we leave...
  • Like
Reactions: 98G
MTVR
749
Waco Texas
Today we cut and fitted much of the 3.5" thick rigid polyiso insulation (R-24 value) for the front and side walls. The floor is already done. We still need to do the ceiling and the drawbridge.20201022_180020.jpg20201022_175928.jpg
