painting over carc
TexasM1079
1998 S&S LMTV M1079
Dallas TX
Not sure if this helps you. I applied raptor liner to the inside of my cab. At first I started to sand the carc. I realized that all I was doing was removing the rough texture that would help adhere the Raptor liner. I pressure washed first. Then addressed any peeling paint. Next I wiped it down with acetone. Turned out very nice.
Did you apply the raptor liner with a roller, brush, or paint gun ? Thanks for the tip. Dan C.
ohsmily
32
Davis, CA
I was reading some older posts in this thread about hazards of stripping paint using physical methods (wire wheel, etc.) I recently stripped two bumper extensions which were in rough shape with multiple layers of paint but also rust in multiple places. I stripped them down outside using an angle grinder and wire wheel. There was a breeze to carry most dust away. Am I going to die of cancer or silicosis? I'm only partly kidding.
It didn't smell great when I was grinding but I figured I was outdoors and no big deal. I'm done having kids so the lead isn't as big of a concern.
P.S.. I primed it and then painted with Rapco 383 green and it looks great.
  • Like
Reactions: 98G
chucky
19,305
TN .
Airborn carc dust is BAD BAD BAD how long since you sanded it? you will be the first to know if you got too much your lungs will be soar to breath .Y OU HAVE GOT TO WEAR GOOD RESPIRATOR ! And the rapco 383 is great paint i shot my truck last fall 4 parts paint 1 part laquer thinner came out great i put 5 gal of material on mine going to put 5 more when it gets a little warmer out.
ohsmily
32
Davis, CA
It was about one week ago. I would say my lungs feel fine. Maybe I lucked out due to the fact that I did this outdoors with a little breeze and it was just 2 parts but it's just 2 parts. In the future I'll wear a respirator mask with filters
TexasM1079
1998 S&S LMTV M1079
Dallas TX
I used the paint gun that came with the Raptor kit that I purchased.
Thanks - I checked out the videos of Raptor lining and saw the application gun - this looks like the way to go, though I don't have a paint booth. Hopefully I can apply this outdoors on a less windy day. I plan to undercoat my JLTV trailer and spray the bed as well. Dan C.
Niuhi
23
Shoreline WA
I guess i should make clear, I am about to bedline the exterior (i have lizard skin on the interior) with Raptor Liner. I have power washed a whole lot of crud off my HMMWV and wonder if i need to prep the old CARC coating anymore than just a good power washing prior to applying the bed liner?
I'm over in the FMTV forum, but noticed your Lizard Skin usage. Are you happy with the results and did it make a big difference. Lizard skin is what I had intended on using in the 1st place, but started to get lazy and thought about just using Dyna Mat. Now I'm kinda leaning back toward the Lizard Skin, both heat and sound deadening formulas. Unfortunately as nicely as they drive, these LMTV's have so much cavernous space inside they sound like a big echoing tin box with sand shoved into the joints. 😁
Niuhi
23
Shoreline WA
I watched a few videos of the Raptor Lining being shot outside. Certainly doesn't have the thickness of say Rhino, but if you're painting over CARC, seems like thinner would be better. I'll be curious to see how it works for you because I wanted to try this over my bumpers and a few other parts.
thoner7
236
NE TN
I’d love to know if your “only power washing” method has held up over time?
Unfortunately it’s only the interior- I want to spray the whole exterior of my humvee
bachman502
58
Chesapeake, VA
It’s held up very well in the interior. I don’t know what other liners are out there. I will say Raptor is a 2 part component mix. Meaning you mix a hardener with it. I wouldn’t waste your time with any rattle can “bed liner”.
thoner7
236
NE TN
Oh yea I was looking at Raptor brand. Or perhaps Durabak as they have a smooth option.
I was mainly asking about your prep - I’d love to just power wash the carc paint ha
