Poll - Who has done the Doghead Relay Conversion
Start Relay Conversion/Upgrade
  • Yes - I have done the conversion
    Votes: 329 60.5%
  • No - I don't plan on doing the conversion
    Votes: 52 9.6%
  • No - I haven't done it but plan on doing it soon.
    Votes: 163 30.0%
charlietango
20
Winnipeg
Subjock, same thing happened to me 3 years ago and it started a wire fire under the hood. At the time I had a spare relay in the glove box and lucky enough scrounged up some wire to splice. Its been that way for 3 years now (still working fine) and funny enough I was just thinking about doing this conversion when it warmed up yesterday, assuming I had pushed my luck already waaaaaaaay too far.
00Buck
Racine, Wi
Did mine today after a friend called me on Wed frantically asking how to stop his starter from running. I knew right a way from reading here what was happening, but couldn't do anything to help him. It is still in the shop getting a new starter, relay, and repairing wiring. It costs me $16.50 for the relay from NAPA, and an hour to install. I was putting it off till spring, but that gremlin was just too close this time. Thanks Doghead for this detailed mod and to all of you who post questions and solutions for me to learn from.
M1911A1
High Springs, FL
Well after reading at length about the "doghead" relay swap it seemed to make a great deal of sense. On my way home from work this afternoon I stopped by the local parts house procured the proper relay and raced home to install it. When I got under the dash to remove and replace I found that the previous owner had already done the "doghead" fix! Wow, I think I'm gonna go buy a lotto ticket!:doghead:happy,happy,happy!
1,184
Read the sticky! It is linked in post #1 of this thread.
It is best to read first, post second.
marand9199
willowbrook, IL
Wow, this thread been going now for a little over two years now. Just completed the DH rely mod today.
Bought my M1009 Sept 2012 and the guy hand just replaced the rely a year before that. after completing the mod I took the relay apart and found all kinds of corrosion inside. (See pics) I can see why these things can fail.
Dylan
Ontario
I get my part tomorrow, as soon as I get my day off I'm going to install it.
I don't want to not do it and regret it later so I have put it off long enough.
Dylan
Ontario
Now I got it done delayed it but its done so that's all that matters at the end. Real easy and simple to do.
At the same time I also thought my starter went but found out one of the bolts that held it broke and just had to get it out and replace it.
Warthog
237
OKC, OK
Welcome NoQuarter. Please add you State to your user profile. It is a site requirement.
KORNDOG
Milwaukee, WI
I did it too. Found the part at sears, #146154. This "kit" comes with terminal nuts and a ground strap.
Since some guys were having trouble finding the Napa version.
REAL cheap insurance against killing a $200 dollar starter, and who knows what else!
Hoolio
Painesville Ohio
I did it on my M 1031 after smoking up the Delco starter.. I went running for a 1/2" wrench to disconnect the battery cables .. After finding out the nuts were 9/16" , My starter was already roached.. Now I have disconnect switches on both batteries.. Did the relay swap and has worked great ever since.. Thanks , Roy
