- 2,799
- 74
- 48
- Mesquite, NV
I am very curious as to what might be causing the leaks - no matter which system you're running or which material your adapters are made of.
The install video for Westfolk's shows the gasket install and warns that it is easy to install wrong - ie with a bubble or not getting it 100% flat.
With that in mind I double checked my son's work when he did that part of the install. I also torqued the first one (to 55 ft lbs) because I was teaching him how to use a torque wrench. Other than that it was pretty much done as per the video by a then 13 year old. He even lubed the gaskets with old oil that happened to be there and didn't get really crazy with the clean up prep.
So far no leaks, no problems. I've done one full oil change and several oil filter only changes (cuz it makes me feel good).
If anyone else has had any problems or did anything special on the install please post it up.
