Purchased a 1943 Ford GPW
Torisco
45
Bishop, California
Torisco
45
Bishop, California
The windshield glass was full of bubbles, broken and cracked at the edges, so they were replaced (the old windshield glass was original!
I welded shut over thirty small holes on the windshield frame alone, not counting the vast number of holes that were also welded over on the body.
I had to make special little shims to weld into the ten holes of the windshield frame that hold the canvass top onto the jeep. The home made bikini hardtop that was on the jeep when purchased was attached to the windshield frame by nuts and bolts thru the ten holes. These nuts and bolts made the holes to large for the original screw in nuts that were used to hold the rag top onto the windshield.
Torisco
45
Bishop, California
Doing other miscellaneous parts such as wire harness connections and steering column. (CONTINUED)
There is also a photo of the special fan that I had to find so that I would not have to use the electric fan in front of the radiator that came with the jeep when purchased. It is completely flat on the radiator side and has excessive fan blade curves to generate greater air flow at low speeds. As the RPM goes up the flexible blades will flatten out the curve position they were in at the lower or idle RPM. (Summit Racing Fan)
Prospector GM
Hesperia Ca
Looks like you are moving right along with your 1943 Ford GPW project [thumbzup] :D . Thanks for all the photos, that you are posting. I like your build thread . Doing a great job Torisco !!!!!!!!!!!!!!!!!!!!!!!!!!!!!:jumpin::jumpin::driver::driver:
Torisco
45
Bishop, California
I waited until I was about 70% done with the restore and then started posting pictures. I thought it would be better to not have any major breaks in time between the restore pictures so it would condense the thread
As of today I am about 95% complete, but the recent snow stopped me. I expect to resume on Monday the 8th if all the snow is gone.
Thanks for the compliment and here are a few pictures of the snowfall.
Torisco
45
Bishop, California
Torisco
45
Bishop, California
There was a lot of body work done. Welding holes, take out dents and dings, weld cracks, and more.
Torisco
45
Bishop, California
Plenty of body work and body accessories work to do on this jeep.
Torisco
45
Bishop, California
A Little dash board hole welding and gas tank sump repairs welded and primer.
Torisco
45
Bishop, California
All new gas line installed and hood installed
Torisco
45
Bishop, California
All windshield work. Pivot bracket, cowl gasket and windshield mounting
