Pyrometers
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
So I was able to pick up some pyro gauges for my trucks. They require a K type coupling. Is this the type that doesn't need power to work?
cranetruck
74
Meadows of Dan, Virginia
Right, a thermocouple generates its own little voltage, which can be displayed by a non-powered gauge (including the K-type). You will need power for illumination, though....
Trango
22
Boulder, CO
If you calculate the amperage of the illumination requirements, you can easily wire a resistor in-line to allow 12v lights to run on 24v.
Best,
Bob
ida34
30
Dexter, MI
Or you could just order 24 volt equivalent bulbs. There is a cross reference in the Technical Articles section and the bulbs are cheap. I ordered some with extras for my gauges and the total was $16 with shipping for 10 bulb total.
Djfreema
Santa Clarita, Ca
Since the subject came up, I purchased a boost guage and pyrometer from Jegs.com a few weeks ago. They were around $130 for the pair made by VDO. In the past I have bought autometer guages and have never had a problem with the guages not function or not having all the hardware. VDO on the other hand, the boost guage did not come with any of the brass fittings or the plastic tube and the pyrometer isnt working. The guages look nice and match the stock guages but I guess you get what you pay for.
OPCOM
27
Dallas, Texas
I used my own tubing and such and use a 15PSI fuel pressure guage for boost.. It was not very hard, even for me, having been called "Mr. clean-wrenches".
Jakob
Louisville, KY
Re: RE: Pyrometers
What all is needed besides the gauge? I like the K-type guage that has the yellow and red bars in it for warnings. I can't really find out anything else about what's need to install this gauge though.
m-35tom
221
eldersburg maryland
RE: Re: RE: Pyrometers
VDO gauge requires 12 volt power and will not work on 24 volts. i calculated the current draw on 12 volts and used a resistor in series with the power to the gauge since it is a constant. i like the VDO better than others since it has a dc to dc amplifier for the meter and should be inherently more accurate.
Djfreema
Santa Clarita, Ca
RE: Re: RE: Re: RE: Pyrometers
Hey Bjorn did you ever get to see how much boost that 757 puts out and at what egt's? Is that blow by entry port factory or did you add that? I would really like to do something like that to keep the fumes in the cab at a minimum.
FreightTrain
Banned
2,730
13
Gadsden,Al
Ummm,actually,Both....Also,if you use 2 gauges you can use standard 12 Volt bulbs.Just Hot bulb 1 to switched power,Ground bulb 1 to Hot bulb 2,Ground bulb 2 to ground.Instant "24V" lighting.
FreightTrain
Banned
2,730
13
Gadsden,Al
oh yea,those are Stewart warner gauges and I used the autometer probe kit.Works perfectly.No power run to them.One gauge is off.100 degree hot.Never goes to zero even when they showed up.I might swap out one of my zero reading ones.I know that when taking off from a light it goes to 900 degrees FAST and then nearly stops.Slowly climbs across the gauge after that and maxes out at around 1150 and WOT.I can hit 1200 on a hill after a long run.Think my truck is about setup perfect!Even though I might have to break out the super shims and adjust the fuel..........once I get a Boost gauge.......
vtach
North Dallas, TX
I put a pyro in my Cummins and the front half of the manifold runs a little hotter and moves up a little quicker than the side with the rear 3 cylinders. It will idle at 300 degrees, cruising at 72mph and 1975 rpm, it will read 610, and I can peg 1500 degrees in 12 seconds from a stop to 84mph. The gauge only reads to 1500 so I don't know how hot it would get 1800 probably (won't try it for obvious reasons).
I would really like to get a little more power in my deuce, but I don't know how much room there is and what the max temps are? My cummins is an 06' and it will take more heat than the older ones. Anyone actually measure the power gain by just adding fuel? My cummins gave me an additional 138HP and 368ft-lbs with just more fuel.
gimpyrobb
27,785
747
Cincy Ohio
Well, I am finally moving forward on this. I have had Stewart Warner gauges like FT, they came w/o probes or lead wires. I have just ordered a
Hewitt pyro gauge(79.47 with LED back light)p/n 010-210 b/br,
3 probes(28.78 each)p/n 015-001-b,
and 4 lead wires(22.20 for the new style-plug and 20.00 for the old style-ring terminals)p/n 035-008(new) p/n 035-004(old style).
I will install all the Hewitt gear and get a baseline of results, then install the SW gauge and see if there is a big temp change. If not I will run the SW gauge with the Hewitt probes and wires on my other trucks. Hewitt
gimpyrobb
27,785
747
Cincy Ohio
According to the numbers, $130.45 for a complete pyro setup. That does not include shipping. I can post the Hewitt # tomorrow if you need it.
