questions on buying a hummer?
Expendable
SoCal
Blazer1987, humvee.net has some good info regarding HMMWVs. follow the link below.
http://hummerknowledgebase.com/HMMWV.html
some quick facts
A1: 6.2L NA Detroit Diesel engine, 3 speed TH400 transmission. some A1s were retrofitted with A2 drivetrain.
A2: 6.5L NA Detroit Diesel engine, 4 speed 4L80e transmission.
I am not familiar with designations of the humvees that got the Turbo Diesel.
Blazer1987
Centerville,MA
Yeah im changing my mind about getting a HMMWV. Knowin most of them are for off road use only. It would be fun but I dont have any property to use it on. Prob. Gonna go with a m1008 maybe. Easier maintenance and availability. I appreciate everyones help and knowledge. Saved me from buying a humvee and getting a big surprise when going to the registry. Thank you
tage
69
LOS ANGELES / CALIFORNIA
:jumpin:Tschuess
dangood
15
Ogden UTAH
Engine smoke could be an injector or something a little simpler than a bad engine. (although there are plenty of high priced Hummer/humvee/hmmwv rigs out there with the crap beat out of them with bad engines and trannies still hobbling down the desert.) My advise would be compression check if you have the time, or at least look for sand in the air cleaner and intake (buddy paid over $25K for one and it had over a cup of sand in the air cleaner and all intake hoses had sand, and tranny had sand, wood chips and all sorts of christmas in it and it had hardly any oil pressure) and check oil pressure at cold (should read 55-60 psi) and at hot (should maintain 25-30 at idle). If oil pressure is low, and drops to 5-8 psi when hot, you prob have a bad engine.
