Rac-15 mre/water heater power cord
1,815
There have been a few threads on these with part numbers and availability discussed. Search the term "combat crockpot"
Storm 51
Just a Grunt
9
Seattle, WA
The manual is available on Liberated Manuals .com.
The manual number is TM 10-7310-241-12 & P.
The wiring diagram is on page 1-12 Change 1.
Storm 51
Storm 51
Just a Grunt
9
Seattle, WA
Those are great prices on connectors!
Seems like they are usually double that.
The stock military wire cable for these units is stranded 14/4. You should be able to get it at any decent hardware store or electrical supply house. I'm sure 14/3 would work just fine too.
Storm 51
Jeepsinker
457
Dry Creek, Louisiana
I can't believe nobody has done a connector conversion on one of these yet. There are HUNDREDS of viable connectors out there that are much easier to get parts for.
Storm 51
Just a Grunt
9
Seattle, WA
O.K., I'll grab the next one I see and let you know. I come across them occasionally for a lot less than what I see them selling for on Ebay. It would be nice to have these more accessible to MV people.
Storm 51
123mack
11
Jemison, AL
It's the same plug that plugs the wiring harness on a 2.5 or 5 ton into the flasher unit. That's what I used to make my power cord.
eagle4g63
34
North/west Indiana
I also made a wire set up for mine, and also put a plug in the dash to hook it to.... if you find the tent receptical sets, they use the exact plugs on the the outlet box(it's what I used for the dash plug) and then just used the cord from the kit....it's already made for you. I'll have to find my pics.
rwminck
Florence SC.
MRE Heater Power?
So I bought a MRE/Water heater online and like a doofis I did not check to see how I am going to hook it up. The plug on the heater has 3 prongs. Anyone know a power cord source for this unit? Thanks
ralph3162
Pleasanton / Texas
Mre Heater Power
Plug needed is an Amphenol MS3106F16-10S MIL-DTL-5015 it can be found with internet search run about 20 to 30 bucks. You then need SO cord 14ga 3 strand cord. a soldering iron. Plug wiring is as follows.
A=22-28 v positive
B=Ground
C=Not used
Also if you want a manual with specs and electrical diagram can be found at www.liberatedmanuals.com TM 10-7310-241-12&P
Also might I suggest a receptacle that can be hard wired into the truck. Amphenol MS3102R16-10P
1,815
Search using the terms "combat crock pot" There is one active thread going on right now which links to another one. Has all the info you need.
