Railroad Forum
Should we have a Railroad Forum?
  • Sure, I don't see why not, we have tanks and few own them.
    Votes: 54 84.4%
  • Nope, trains is dumb!
    Votes: 1 1.6%
  • Ferro is nuts
    Votes: 9 14.1%
scottgs
Oak Ridge, TN
No Military Land Rover forum either. Keeping in mind that Land Rovers are used by the US Army, and that military Land Rovers actually show up for the Steel Soldiers rallies, and they go on the trail rides and the convoys, unlike a large portion of vehicles which do have dedicated sections in the forums.
Just be glad this "I want it" thread hasn't been locked yet. ;)
zout
155
Columbus Georgia
I have a physic hotline # - and I forsee an end to this thread quickly - it is touching base with uncontrolled pent up hostility.
zout
155
Columbus Georgia
It was already predestined that hotline I have would pay off - I only bet on sure things - please stand by for end results. I see It in my 8 ball
vtdeucedriver
40
Vermont
:rant: :soapbox:
aua Nevermind.
hndrsonj
Senior Chief/Moderator
377
Cheyenne, WY
Vtdeucedriver, there is ZERO reason to have a RR forum. We are trying to reduce the multiple forums.
EMD567
Driver for the Ga Mafia
Aiken SC
AH yes, the death song of another GE product. It will soon be turned into little pieces, and sent to China.
trukhead
dane/wi
A lot of them will load up with fuel while idleing all night during cold weather then catch fire in the exhaust when going back into service.
I heard the term "cold lock" on the old generation diesel engines that are set out to idle in the cold and the fuel builds up and the engine locks up with results such as bent rods. Have you heard of or seen this condition?
steelypip
68
Charlottesville, VA
I haven't heard the term, but I've heard most commonly of fuel dilution of oil resulting in poor lubricity and low oil viscosity, followed by rapid ring and bore wear, followed by the engine running away as it sucks fuel and lube oil past the rings.
There's also a variant of badness on blower scavenged diesels involving blowby puddling in the intake tract. It idles fine for a good long while, but then the operators goose it and it sucks all the oil into the engine causing an overspeed or other bad things.
The most common variant is probably extreme wet-stacking. This was common on the Deltic locomotives because they had significantly more power available than was commonly needed, so the power units spent a lot of time at idle. You usually just get an exhaust system fire from this, but most exhaust systems (and turbos, and engine bays) aren't designed to cope with extended exposure to a high temperature fire in the plumbing.
swbradley1
Modertator
1,929
Dayton, OH
Thought some of you guys that ever lost a turbo in a truck would like to see one fail in epic proportions looks like it had started to run away burning its own crankcase oil.
That has to be some of the cleanest crankcase oil ever to burn with no smoke at the end.
michigandon
Wake Forest, NC
GE's have a habit of spontaneously combusting if you so much as look at them the wrong way.
Take a look at the ratio of GE's that are 10-15 yrs old and sitting in the deadline, vs the EMDs that are 25, 30, 40 yrs old that are very much still alive and kickin'! I rest my case.
USAFSS-ColdWarrior
Chaplain
6,238
