Rear driveshaft u joint bolts stripped
319cssb
221
Easley SC
I have used a product called friction grip drops. It's a paste that you put on the bolt and it increases the friction, this way your 6 point socket has more leverage.
Worked like a charm for me. I also used some penetrating fluid.
erasedhammer
61
Maryland
Honestly the whole driveshaft needs replacing anyway.
I have a cheap harbor freight reciprocating saw, with a carbide blade. So I'm just cutting through the bolt.
erasedhammer
61
Maryland
I got the driveshaft out. Dropped the torque converter cover and now I see that it does have some wear but the teeth are intact. Possible wrong starter?
Retiredwarhorses
4,603
Brentwood, Calif
Getting towed to the auto shop is problematic cause the base police aren't too keen on moving the vehicle.
Yeah I found a guys write up on the flywheel replacement, I have the bolts and I've rigged up something to support the t-case and tranny, so I think I'm good there.
That makes absolutely no sense...but like your HMMWV adventures, I suspect this will be no different.
erasedhammer
61
Maryland
It's not like I want to do this fix in a parking lot. I've called around to friends and rental companies trying to find a trailer, dolly, something that could work. All of them refused. I asked the base police if I could flat tow the truck not even a mile to the shop and they said no.
I'm just working the cards I've been delt.
Retiredwarhorses
4,603
Brentwood, Calif
Call a tow truck...and tell the Federal cops to suck it, really.
that or go talk with your First sergeant, none of this makes much sense to me...what base is this?
cucvrus
10,501
Jonestown Pennsylvania
That starter is stuck out there in the fly wheel teeth. Disconnect the batteries and get the starter off and checked. That is where I would start. Get a flywheel tool and turn the flywheel 360* and inspect the teeth first hand. Pictures and report back. Good Luck.
erasedhammer
61
Maryland
Turns out the starter bolt was loose and caused a misalignment. Tightened it and the pinion gear popped back.
Cranks fine now, but itll only run on ether. Definitely have a fuel delivery problem.
On a side note AAA has refused to tow me now.
319cssb
221
Easley SC
How did you get out in that parking lot to begin with, if you have fuel problems?
oh wait, youre doing a pick up in ft meade? Is that it?
erasedhammer
61
Maryland
Called AAA, 4 times, and escorted the tow truck on base. Would not recommend, as AAA has basically disowned my membership and is charging me for every tow, still cheaper than a private tow truck company though.
erasedhammer
61
Maryland
Yeah, registration is in the mail right now, so they had to charge me. Rental trailer would have been cheaper, but theres no where around me that rents one big enough.
319cssb
221
Easley SC
you can fit a M1028 on a galvanized u-haul trailer. You might have to take the dually tires off, it it has them.
tobyS
840
IN
I've hauled several truck beds using bales of straw in the tracks on those trailers. There is no way that a 1028 should be hauled on one.
Retiredwarhorses
4,603
Brentwood, Calif
Because you have exceeded your membership limits...based on your history, maybe you would be better off owning your own two truck?
