Also check you transfer case and make sure it's in high gear. The handle all the way up.is there a way to tell if there isnt enough pressure being built up? is there compression that should be there but might not, how do i check for compression. also when it ran, they said it wouldn't go over 20 mph. is this a symptom to my problem?
Did you try the TM's in the Technical manuals section?Anyone got a link to a post that shows how to get everything oiled and greased up? I don't want to miss greasing up a joint cause I missed it until I smell smoke
That's the flame heater for cold starts. Irrelevant for your starting issues. Most people delete them when they start to leak.
That's a memorable description.The injectors should be shooting fuel 3-4 FEET, not inches. 3000 skin-piercing psi.
First thought to mind about the "5:00" position vs "7:00" position is reversing:Pull the plug out of the middle of the hydraulic head and measure how much the plunger travels up and down when you turn the engine over.
Open this up and make sure it's free
Dunno, ain't been that deep. Doubt it. Bet rusty knows.First thought to mind about the "5:00" position vs "7:00" position is reversing:
- does the set-up allow for the possibility of reversing the installation of the mechanism at all?
Does that make any sense?
