Rhino Tire Carrier - Washer Specs
HmmwvTim
102
IL
I've got every one of those washers except the black one. That's the one I need.
Seems to be the case for most people parting together one of these. Now you know the dimensions. Would be nice if someone started to make these and sell them.
Action
1,564
East Tennessee
Dont have the skew but it is in the grade 8 thick washer box. It will be hard to miss. As for the black one, that might have to be special ordered or custom made. I would just get a qtr inch plate and ask a machine shop to cut 2 to 2.25” outside diameter and a half inch inside diameter circle with a cnc. Might be cheap.
Might be cheap or might be an hour minimum labor.
TNDRIVER
577
Cleveland,TN
got it on. Took some photos. The little mxc washer is the spacer I used so I can keep the mudflaps on the outside. It is slightly thinner than the mudflap but there is a patrusion on the bumper and the mud flaps compensates for this with a slightly hollowed out section behind the metal. That washer is 80 cents at ace hardware. The bolt that mounts the post could be a qtr to a half inch longer. I might get me a longer one. Hope this helps.
View attachment 867434View attachment 867435View attachment 867436View attachment 867437View attachment 867438View attachment 867439
My two cents for what it's worth, Tractor Supply where I live sales a "shim" in the same size as the large brass washers. Cad plated I think, stocked with the 3 point hitch goodies,they work for me.
